Question about Depo Auto Parts Hyundai Elantra New AC Condenser Cooling Fan Assembly-Shroud Blade Motor 2001 2002 2003 2004 2005 2006 OEM 97730-2D000
HOW CAN I find a replacement shroud for a Dometic QC135-A roof mounted AC. Dometic no longer makes them. 32x22.25 x 12.25.
Posted by Larry Robinson on
Dometic roof top rv ac not cooling
sounds like it is low on freon have someone check with gage and add more if nedded.
Jul 11, 2014 | Dometic Rooftop RV Air Conditioner
Duo therm ac in my rv quit when the converter burned up does the ac need 12v to work?
there is a fuse located under the shroud on the roof AC on a circuit board that controls the thermostat to turn on the power to the Air Conditioner replace it it is marked F-1 or, on some F-2 etc.
the air conditioner works on both DC voltage for the thermostat and AC voltage for the compressor
Sep 08, 2013 | Dometic 3312024.015 Duo Therm Comfort...
Where can I find a shroud for my 2003 model 59516.331 duo-therm high efficiency Dometic roof mounted dometic RV air conditioner?
Try googeling Camping world ,Adventurerv ,or best rv and truck supplies ,these are all in the USA who deliver to Australia.I usually find that it is much cheaper to buy parts like this from the US even with the delivery charge.
Good Luck John
Oct 11, 2012 | Dometic Rooftop RV Air Conditioner
Need a replacement r v air conditioner shroud polaris by dometic 28inches wide 41 7/8 inches long & 9 1/2 inches high
Can you get model number of bottom of upper unit, from inside the trailer? The roof unit model number will make it easier to find replacement shroud.
Sep 27, 2012 | Dometic Rooftop RV Air Conditioner
My Dometic roof mounted aircon appears to discharge the water straight onto the roof. 1) Is this normal operation. 2) Is there a drain tube fitted, and if yes, where would I find it? Assistance will be...
Yes it is normal for AC to drain on to roof as the drain holes are in base of AC unit. The time to worry is when you don't see it draining on to roof, as this indicates holes may be plugged.
Jan 30, 2011 | Dometic Rooftop RV Air Conditioner
Relay (?) sticking Dometic RV rooftop AC
Go up on the roof of the unit and remove the AC Shroud. With the unit running, see if you can pinpoint where the sound is coming from. The only thing on the entire AC that would make that much of a vibration would be the fan motor. Not sure what would cause the fan motor to do this. The compressor may do that but only if the windings are bad and then it would not be cooling.
Jun 30, 2009 | Dometic Rooftop RV Air Conditioner
Older Penguin roof shroud, new style fit?
I just replaced my two 620315.321 shrouds with the newer style without any problems. I went to the Camping World site (and called them) with model no. and they knew what to send me. I also found that they had the best price at $79.00 (member price) with free shipping.
I didnt check your shroud part no.s, but think you will be ok if you do as I did.
If you have any question about installing, you can email me at [email protected]
May 05, 2009 | Dometic Rooftop RV Air Conditioner
RV Dometic AC Comfort Control Double EE Problem
I have a dometic duo-therm. The unit works great and fan blows strong and both high and low work., but air is coming out of the ceiling unit rather than the duct work. The bedroom unit works OK, but the air is strong out of one duct, and not much comes out of the others. The front unit only has air coming out on the A/C unit and none out of the ducts.
Mar 24, 2008 | Dometic Rooftop RV Air Conditioner
Depo Auto Parts Hyundai Elantra New AC Condenser Cooling Fan Assembly-Shroud Blade Motor 2001 2002 2003 2004 2005 2006 OEM 97730-2D000 Logo
824 people viewed this question
Top Depo Auto Parts Computers & Internet Experts
Tom Chichester
Kar Volk
Andrew Taylor
Andrew Taylor
Are you a Depo Auto Parts Computer and Internet Expert? Answer questions, earn points and help others
