Question about Dometic Rooftop RV Air Conditioner
Need to replace shroud on my QC135-A Dometic AC. 1982 Chevy squire. 32x22.25x12.25?
Posted by Larry Robinson on
4 Related Answers
Anonymous
SOURCE: parts manual for dometic QC135-A air conditioner ?
Hi, have same air conditioner unit, have all manuals that I can copy and send to you if interested. email me at [email protected].
Posted on Jul 26, 2010
motor1258
Mike Butler
  • 6674 Answers
SOURCE: Where can I find a replacement shroud for my
Try any local RV dealer, camping world, etc , or call 1-800-544-4881 to order directly from Dometic.
This link will take you to a dealer locator for your info on dealers in your area.( http://www.dometic.com/enus/Americas/USA/Customer-Support/Dealer-Locator/ ). Have your model number ready. Most dealers may even have a used one to sell you if you ask.
Posted on Oct 01, 2011
John Fulcher
  • 9 Answers
SOURCE: Where can I find a shroud for my 2003 model 59516.331 duo-therm high efficiency Dometic roof mounted dometic RV air conditioner?
Try googeling Camping world ,Adventurerv ,or best rv and truck supplies ,these are all in the USA who deliver to Australia.I usually find that it is much cheaper to buy parts like this from the US even with the delivery charge.
Good Luck John
Posted on Oct 12, 2012
gtmerkley
George Merkley
  • 194 Answers
SOURCE: Dometic roof top rv ac not cooling
sounds like it is low on freon have someone check with gage and add more if nedded.
Posted on Jul 11, 2014
Where do i find the model # on rooftop dometic ac? i lost the cover and need to order a new one?
Regarding location of the model number, look under the ceiling bezel on the inside of the RV. Also, many aftermarket replacement shrouds will fit several different models of Domentic air conditioners. You might want to check out pplmotorhomes.com
Jan 23, 2015 | Dometic Rooftop RV Air Conditioner
Duo therm ac in my rv quit when the converter burned up does the ac need 12v to work?
there is a fuse located under the shroud on the roof AC on a circuit board that controls the thermostat to turn on the power to the Air Conditioner replace it it is marked F-1 or, on some F-2 etc.
the air conditioner works on both DC voltage for the thermostat and AC voltage for the compressor
Sep 08, 2013 | Dometic 3312024.015 Duo Therm Comfort...
Trying to install dometic shroud 3309518.003
install low end of shroud down over band then pivot high end down over band. if still a problem take a strap and tighten around band to hold in.
Dec 08, 2012 | Dometic 3309518.003 Brisk Air Conditioner...
Need a replacement r v air conditioner shroud polaris by dometic 28inches wide 41 7/8 inches long & 9 1/2 inches high
Can you get model number of bottom of upper unit, from inside the trailer? The roof unit model number will make it easier to find replacement shroud.
Sep 27, 2012 | Dometic Rooftop RV Air Conditioner
I need to replace a broken shroud on a Duo-Therm Brisk Air Model # 59715.531 Where can I purchase a matching shroud?
americanrvcompany.com Once on the site go to air conditioners on left hand side then Dometic A/C. They should have what your looking for.
Jul 05, 2011 | Dometic 57915531 Air Conditioner
Parts manual for dometic QC135-A air conditioner ?
Jun 04, 2010 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
277 people viewed this question
Top Dometic Heating & Cooling Experts
Marvin
Marvin
Sheldon Dedek
Mike
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
