Water Heaters Logo
Posted on Nov 25, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can i get a manual on a bosch gruppe water heater
Junker bosch gruppe manual water heater
Kaye Day
Level 3:
  • Master 744 Answers
  • Posted on Nov 25, 2015
 Kaye Day
Master
Level 3:
Answers
744
Questions
Helped
223261
Points
13385
Having problem finding one. Is there a model #?
Also what are you trying to find out? as sometime googling the problem finds a solution faster than googling manual.
How do I get a Junkers (Bosch) tankless water heater run with reduced water pressure?
the low pressure/flow minimum is for safety and protection of unit and no adjustment to do so
Junkers wr11 has no spark and no power
Is it gas or electric? if it is gas and has a pilot, and the pilot is out. If you don't smell gas go through the start pilot proceedure. when the pilot is running it produces a small electric current sufficient to hold the main gas valve open; then the temperture sensor allows the unit to keep the water heated.
Where can I download a Boschw14 b31 gas Heater Manual
Is this a water heater? Bosch site might have manual. And service bulletins, but I have not heard of that model.
http://www.bosch-climate.us/Bosch-Hot-Water/
Call local service technician who is qualified to work on tankless computer that heats water.
You can fix any brand tankless computer, any problem, same day, yourself by replacing 1 part: the whole thing:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
l
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
Free download manual junkers wr11water heater
1) Web search 'WR11 water heater .pdf' shows Bosch WR11 manual
http://www.boschsupportline.nl/content/files/TechDocs/Geisers/6720607884.pdf
Junkers water geyser pilot is on but main burner will not start
http://documents.junkers.com/download/pdf/file/7181465057.pdf Sometimes there are several parts on this model to find buit beware on some marketing technical made differences inbetween one year of build there can be some modifications inside.
Succes
My Ariston 4 gallon water heater is given out hot dirty water?... Any Suggestions?
1) Dirty water implies degraded metal inside unit:
The anode rod protects metal parts. Once anode is depleted, metal parts react with water.
2) Open following troubleshoot pdf showing Ariston parts
http://waterheatertimer.org/pdf/How-to-Troubleshoot-Bosch-Ariston-Water-Heater.pdf
3) Ariston manual: Read manual cover to cover, make sure water heater receives yearly maintenance as outline in manual.
http://waterheatertimer.org/pdf/Bosch-GL_English.pdf
4) Information on anode rods
http://waterheatertimer.org/Replace-anode-rod.html
5) For Bosch gas and electric tankless: Open following link for troubleshooting resources, including Bosch contact information, typical manuals, error codes, tech support, parts, fuel-saver calculator, service bulletins, water heater forum, fixya links, disclaimers, and links for finding service technician.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
6) Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
1helpful
Faulty Junkers water heater
first find out from your manual what the flashing red light means...that should narrow your search---could be a thermocouple shot,a rubber diphragm in the gas valve has weakened and not operated, or gas pressure into the appliance may suddenly be too low, or springs in gas valve may have worn out---very many possibilities
Top Bosch Water Heaters Experts
john h
ZJ Limited
ZJ Limited
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
