Question about LG 42PX5D 42 in. Plasma HDTV
Horizonal line in plasma tv - LG 42PX5D 42 in. Plasma HDTV
Posted by mr zif001 on
Droped tv have vertical and horizonal colored lines. reset did not fix
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Nov 05, 2016 | Televison & Video
How do i fix horizonal lines in a 50 inch Samsung Plasma Tv
Check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jul 29, 2015 | Samsung Televison & Video
Horizonal line across middle of screen top half of picture perfect bottom half has small lines in picture hitachi hd S 69 plasma
I'm not sure if this model is the one that has resistors that go bad. You can actually purchase a pack of resistors in a kit. It will come with solder, the resistors and instructions. You can lay the tv out and take the circuit board out to find the blown components, and replace the bad ones. Takes about an hour start to finish and will cost around $65.00. It has been a few years since I did this, so I'm not sure on the price.
Apr 04, 2015 | Hitachi UltraVision 55HDS69 55 in. Plasma...
My samsung plasma tv has horizonal lines how can i fix it.
solder the connections to the lcd screen on the sides.. or replace the board. the resistors are the ones that need new solder. you can also replace the board or send it in to be refurbish at low cost.. fast turn around at www.tvpartsandmanuals.com or you can get the repair manual with parts
Nov 24, 2011 | Samsung HP-R5052 50 in. Plasma HDTV
I purchased the tv in 2007 and it has been great until now. The picture went out a few months ago around the time we had all of our plug outlets replaced by an electrician. I initially had audio but no...
If you wish to get some details; visit the site linked here. Pull up older posts.
Aug 16, 2017 | Panasonic TH58PX600U 58 in. Plasma HDTV
Tv is about 4 years old. Suddenly developed two
Your plasma screen is made up of 1080 verticle lines and now a few of these lines are not working. This is the screen itself and needs replacing.
May 22, 2010 | Samsung HP-T4254 42 in. Plasma Television
I have a LG Plasma Flat screen TV. I purchased it
With seeing the picture it will be hard fro me to tell what..I am going to guess according to the information you've provided.
It could a buffer or a signal board(s). This TV is only 4 Months old I would call LG and file a warranty claim. LG (800) 243-0000
Best of luck
N Sabre
Nov 08, 2009 | LG 50PX5D 50 in. Plasma HDTV
There is a horizonal line across the screen about an inch wide, can this be fixed, how much and how hard
plasma control board defective,or plasma display defective. Solution is go to the repair store, normaly is the diagnostics is " Buy a new one"
Oct 31, 2009 | LG 42PX5D 42 in. Plasma HDTV
One black horizonal line 1/8 thick on samsung plasma tv
It depends on color of line.
if the line is black, need to replce PDP module(panel)
But, the line looks like noise, need to change the main board.
Sep 13, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Horizonal line
I think you have a fault on the picture frame board. If you can check for this yourself or find a competant technician. Hope this helps.
Apr 02, 2008 | RCA F32650 32" TV
LG 42PX5D 42 in. Plasma HDTV Logo
129 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
