MX-780. Why can't I change channels? - Televison & Video
Posted by Steven Kakowa on
Kaye Day
  • 744 Answers
Need assistance or have questions?
Our Customer Service Support Center is here to help.
Call (914) 835-4484 to speak with a customer service
representative or email us at [email protected]
500 Mamaroneck Avenue, Harrison, NY 10528
Phone: (914) 835-4484 Fax: (914) 835-4532
www.universalremote.com
http://www.universalremote.com/pdf/MX-780_Owners_Manual.pdf
Posted on Nov 25, 2015
The mx-780 remote works very rarily. It won't change channels, guide etc. It controls volume ok. I've changed the batteries several times. very frustrated.
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience. In some cases, the remote control might need to clean.
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
https://youtu.be/wUpnETSm6_k
Aug 18, 2016 | Universal Remote Control MX-780 48-Device...
Mx 780 remote control channel and volume frozen
There could be many reasons why this happened. A corrupt or missing IR command, or the remote. An authorized dealer and programmer could help by uploading your configuration file and investigating; contact Total Control Remotes totalcontrolremotes.com for help.
Sep 30, 2014 | Universal Remote Control MX-780 48-Device...
Non responsive buttons
You have to open up the remote. The underside of each button has a black disk. Clean each button with a pencil eraser. Then look at the circuit board. Where each of the black discs would make contact (looks like two "E"s facing each other) clean each of those with the eraser. But the remote back together and all the buttons will be responsive.
Jan 17, 2014 | Universal Remote Control Universal Remote...
The buttons on remote stick. When I press FF, Play, List, etc. it doesn't make the connection. If I press and hold it will sometimes work.
The remote is failing, if buttons are sticking its not worth repairing. Go to ebay and search for a used remote, and buy it. Search for MX-7800 remote.
Dec 19, 2013 | Universal Remote Control Universal Remote...
Replaced batteries in universal remote model mx-780 but nothing happens
If you have replaced the batteries, all the previous settings will be lost. You have to set it again, with the set-up codes to your device. If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
Oct 28, 2013 | Universal Remote Control MX-780 48-Device...
Its flashing UC MX-780 and I can;t get it to do anything its frozen and tv can;t be shut off or anything
I had the same problem. My URC MX-780 remote with fresh batteries just alternately flashed between the logo screens. It turned out that our fresh batteries weren't so fresh. Fortunately I have a multi-meter so was able to see that three of the four batteries were actually much less than full power. So I went through the 24pack of Duracells and discovered that about 75% of them were the same; low power. I found four that were close to full power and the remote was back up and running! I'm now making a claim with Duracell as the package came with a 10yr storage guarantee. The batteries were stamped best before MAR2027.
Oct 19, 2013 | Universal Remote Control Model MX-780
Universal Remote MX-780
replace the batteries+retight the spring with plier for better contacts. clean it with alcohol isopropyl. and test again.
If the problem persist use the digital camer or cell with camera, and iluminate the camera the LED will be ON, if do not, open the remote control, clean the keypads for corrosion, and use alcohol isopropyl . and test it again. God bless you
Jun 19, 2013 | Universal Remote Control MX-780 48-Device...
MX-980 the remote won't change channels on the tv
Find a URC dealer near you and have them check the remote
Apr 13, 2013 | Universal Remote Control MX980 LCD Remote...
Controller will only turn equipment on and off. Can't do anything else, ie: adjust volume, change channel, etc. Universal MX-900 Remote
Hello, Reset the remote control and use with the equipment . If it does adjust volume, change channel. then use have to get another one of different model
May 20, 2010 | Universal MX-900 Remote Control
Televison & Video Logo
1,370 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
