Hi Rodney.
the main change from natural gas to propane is that propane has a bit higher energy content than natural gas, so you may heat things a bit faster. The particulars will depend on your specific make and model of range, but, for instance, with my KitchenAid gas range, the primary difference was getting a slightly different connection orifice made to give proper propane flow and pressure. The install kit may also have listings for necessary delivery pressure ranges from you propane source. If the range is built in, it might be a bit of a pain to get at the gas connections, and it's best done by a professional who will know the proper fittings, seals, and pressure tests to do to make sure you aren't leaking gas all over your kitchen.
That said, it's likely not a particularly big deal.
Good Luck!
D
SOURCE: Natural Gas to Propane for Ge xl44 Gas range
The kit is located at the rear of the range right near the gas valve, there are probably 5 spuds and an extender for the large burner, directions are with the range. For the bake and broil you will need to tighten the brass orifice nuts down as tight as possible, also the brass nut on the gas valve needs to be reversed
your local LP dealer should be able to do this for you if you are uncomfortable doing it yourself.
SOURCE: Converting GE XL 44 Gas range from propane to natuiral gas
I needed parts for my GE XL44 propane converted stove. This site was very helpful. I found the part and there is online live help or toll free help. Go to: AppliancePartsPros.com
Thanks,
nnb704
SOURCE: Converting from natural gas to propane
Where do all orifices go on anything gas? Right there where the burner meets gas valve. The air shutter sits right in front of the orifice for proper air to gas ratio right.Go out and look at yer gas grill. Where the burners meet the gas valve ye shall find the orifice.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Converting a Propane Thermador 36" range to Natural Gas
I have the same range but need to convert it from natural gas to propane....we should trade...9j antiques
