Question about Dell Computers & Internet
How to fix a dell laptop
Battery won't charge
Posted by Ivan Bernal on
Kaye Day
  • 744 Answers
What kind of Dell laptop do you have?
If you slowly wiggle at the connection does the connection icon flash back and forth to and from being connected and charging to not charging? Support Dell US
Try Dell site for diagnostic help and possible battery recall.
Posted on Nov 23, 2015
Testimonial: "It was the battery, thanks for the reply"
Dell inspiron M5030 won't charge, green light is
This is a common problem. It may be that the charger is dammaged. these Dell chargers have a micro thin communication cable in them that tell the charger to charge the battery. this micro thin cable can often break. Its use it to prevent the laptop battery from over charging, but if it breaks or becomed broken inside tha charger cable, then the laptop simply won't get the charge signal and the battery won't charge. If this is the case, then you will need to replace the charger with another Dell charger compatible with your laptop
Dec 23, 2012 | Computers & Internet
Batery won't charge new battery n plug
You may have the wrong AC adaptor, Dell is very picky when it comes to Power adaptors, it must be original OEM Dell for the laptop to recognize it, any after market no name brand even though it has the right specs and is made for your model will power your laptop but the circuit to charge your battery will automatically be closed
Nov 17, 2012 | Dell Studio 1737 Laptop
My N5010 dell laptop battery won't charge anymore. Could I just need a new battery, or charger, or could there be something else going on internally that I need to know about? For the most part, I
If your laptop is still under warranty, contact dell and they should be able to fix it free of charge, The same thing happened to my laptop a few years ago and fortunately, it is still under warranty, The fault is the charger itself which dell replaced free of charge.
Jun 26, 2012 | Dell Inspiron N5010 Laptop Core I5...
Charging problem of dell pp41L, it works as an ac online power bt it doesn't charge it.
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
May 20, 2012 | Dell Computers & Internet
My laptop is dell inspiron N4030 and battery does not last long
Apr 01, 2012 | Dell Inspiron Computers & Internet
Laptop Battery Won T Charge on a laptop dell inspiron 1525
Battery could be dead and won't hold another charge. Batteries only last for so long until you have to replace them. If you laptop is ok with the AC Adapter & Power Cord meaning it boots and allows you to work in windows, then the battery is definitely dead.
Mar 19, 2012 | Dell Computers & Internet
My battery won't charge
Nov 06, 2011 | Dell XPS M1330 Notebook
My dell laptop doesnot work proberly if we power on a dell laptop. adopter let should be off then remove from the lap power will be on. whats the problem
Aug 16, 2011 | Computers & Internet
Hello, the battery on my dell vostro 1500 is fully charged, at 65% of its life and passes the dell diagnostic tool, but.. when i take out the plug the battery fails in less than 5 seconds. any help is...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 05, 2011 | Dell Vostro 1500 Notebook
BATTERY WON´T CHARGE ON DELL C600
It is possible the battery where the contacts from the laptop fit into or the gold colored contacts themselves need to be repaired. Worst case, the spill short circuited the contacts on the board, in which case you will have to replace the board. I would suggest really cleaning the gold contacts on the laptop and the small slots on the battery itself with a Q-tip with a little bit of rubbing alcohol on it. Please make sure both areas are totally dry before reassembling the battery.
Good Luck,
NOLA Tech
Jan 29, 2010 | Dell Latitude C610/C600 Notebook
Open Questions:
Computers & Internet Logo
46 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
