Computers & Internet Logo
Question about O2 Xda II mini
No sound from speakers all other functions work. 97 Chrysler lhs infinity system
Posted by jwwilliams2 on
1999 Chrysler Town and Country with an Infinity Stereo, trying to install an aftermarket radio it powers on just fine but no sound
Can't suggest anything except go to installdr.com and search out your vehicle's wiring info. Couple guys I work with used that site with success on their aftermarket installations.
Good luck,
Bill
1999 dodge grand caravan with The stock Chrysler/Infinity sound system
You can use the amps if your replacement speakers have the same or higher resistance as compared to the original speakers.
Does the fuel pump on a 97 chrysler lhs make sound when the key is on?
check the fuses for the fuel pump then if its good check the wiring for the system.there is also a pump relay in the system to check,if there is no power to the tank unit then changing the pump is not going to fix the problem.
When I put oil in my 97 chrysler lhs and start the car, the oil just pours out. What could be the problem?
Is your oil coming out of your dipstick?If it is ,its your engine not breathing!
Its an oil separator fault or oil breather system ,as we call it in Europe.Your breather is blocked .
1helpful
Im installing a new stereo for my 1995 chrysler lhs. the stereo works, but why cant i get any sound?
It sounds like you have the "Infinity System". The accessory/antenna wire has to be hooked up to the power wire for the factory installed amplifier (should be located under the passenger's seat). Locate the wire from the original harness and hook it to the amp wire. I hope that helps. Please rate my assistance and leave a testimonial.
I have been having to turn the key back slightly after starting my 97 LHS to get the accessories (heater/ac windows ) etc to work. This worked for a bit but now doesn't work. I have read the Chilton book...
According to the symptoms you are mentioning it sounds like you will need to replace both the ignition lock cylinder and the interlock cassette.
The battery died now the AC and vents blows hot air all the time after inatalling the new battery 97 LHS
Try adding some freon gas to the system.Thank you for asking and I hope this helps you.Please leave me a 4 thumbs up.
Jvc deck same problem, powers on and functions but no sound
the car is equiped with an amplifier. there is a black wire that you didn't connect. just connect it to the blue with white wire from your radio and it should work.
Will the blower power modules from a 1997,1998,1999,work on a 1996 chrysler.
Don't see a LHS for 1998, just compared 96 and 97, 2 different parts although same engine. They must have modified the heater/ac system in 98. From what I can tell, the 96 has a bracket attached to the motor whereas the 97 doesn't . If you were to remove the old blower motor and bring it to the junkyard and check it against the 97 or newer blower motors, it's possible that its just a matter of retrofitting the bracket off your broken motor to the newer model. Hope this helps and Best of Luck to you!
1helpful
Open Questions:
See all O2 Xda II mini Questions
Top O2 Computers & Internet Experts
Ekse
Muzahura Frank
xxxxxx xxx
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
