Question about Motorola Talkabout T5320 (14 Channels) 2-Way Radio
Motorolla talkabout T5320 batteries corroded inside and now it is erratic and unrepsonsive. Is there a fix. I cleaned the corrosion and it does not appear to be dirty.
Posted by stephanie on
eradiostore
  • Motorola Master
  • 1,658 Answers
It is possible your radio is beyond repair. The most you can do is clean the springs and contacts with a pencil eraser or soft cloth. Erratic behavior is a sign you are only getting a partial connection.
Posted on Dec 17, 2015
John L radiodude365
    Master:
  • Motorola Master
  • 570 Answers
Clean it again. Corrosion is hard to see. Depending on the radio, I use a wire brush on a Dremel or pencil eraser. Sometimes really mild sandpaper. Be careful not to bend the contacts to the battery.
Posted on Dec 02, 2015
Kazimierz
    New Friend:
  • 24 Answers
Probably corroded wires connected to the gills or springs
Posted on Nov 30, 2015
1 Related Answer
Anonymous
  • 250 Answers
SOURCE: Will a Motorola TalkAbout T5320 transmit to a Motorola TalkAbout T5530?
Hello Blindmaster,
Check the Continuous Tone Coded Squelch (CTCSS) settings on all the radios. (Note that some manufacturers refer to this feature as a “Privacy Code” or “Quiet Code.” The actual name of the feature may vary.) This feature encodes a low-frequency signal on your radio transmission. This signal is below the range of human hearing but can be detected by other radios. When the CTCSS feature is active your radio will ignore any signal that it receives that does not have the proper tone encoded on it.
In order for these radios to communicate, all of the radios need to be on the same channel and have the same CTCSS code programmed or the CTCSS feature must be disabled.
I suspect that CTCSS is activated on your T5530s but is not enabled on your T5320. This would result in the situation you describe.
Also take note that when using different brands / models of radios to communicate with one another that the CTCSS code numbering scheme may not necessarily be the same from radio to radio. For instance, CTCSS code “4” on the Motorola TalkAbout series actually corresponds to code “A” on the Motorola Sport models.
Best Regards,
Agent Ken
Go Ahead. Use Us.
Posted on Apr 07, 2008
How do I unlock a Motorola talkabout
Press and hold the Menu button (the center section with the + and - buttons to the sides) until you hear a beep (3 seconds or so). After that, when you press and release the Menu button, the Channel number should flash indicating that you can change the channel. In the future, you can toggle the keypad lock by pressing and holding the Menu button.
You can find more information on the Keypad Lock feature in the manual. See page 14 and page 21. The manual is available from ManualsLib: https://www.manualslib.com/manual/106993/Motorola-Talkabout-T5320.html . For the diagram of the Motorola Talkabout T5320, see https://www.manualslib.com/manual/106993/Motorola-Talkabout-T5320.html?page=14#manual . The Keypad Lock is described here: https://www.manualslib.com/manual/106993/Motorola-Talkabout-T5320.html?page=21#manual .
I hope this helps. I usually use my Motorola Talkabout radios with the keypad lock active. I hit the various button accidentally when working in the field.
Aug 28, 2018 | Motorola Radio Communications
Constant static on talkabout t5320
Could be a sign of a bad battery. Static is a good indicator of a rechargeable battery nearing end of life.
Jan 18, 2014 | Motorola Talkabout T5320 (14 Channels)...
Can't charge motorolla talkabout T6500 battery
Hi treva,
These little radios are are real problem when it comes to batteries.
Not only do they eat batteries, but due to requires numerous recharging, you soon burn the poor batteries out.
Motorola is a great brand, unfortunately these little radios are made in great mass under license in good old China for a cheap price, and in there lies the problem....
You only get what you pay for...
Cheap & nasty.
I have answered numerous queries regarding this very problem with these battery munchers.
Sorry that I can't give you a real solution, but if you pay peanuts, you get monkeys.
Best advice is to buy a good 5 watt CB radio on ebay with charger, they're reasonably priced and if something goes amiss, there are definate fixes for them.
Sorry I could not give any other solution.
Cheers,
Peter
Jan 15, 2013 | Motorola Talkabout T6500 Rechargeable Two...
In my Motorola t6320 Talkabout, some of the battery connectors have corroded and broken off. Can the be replaced?
The battery contacts are the part you are describing as missing or corrosion damaged. These parts are not available from Motorola for replacement in this radio. Your best solution is to replace the radio. Sorry.
Best regards.
May 31, 2012 | Motorola Talkabout T6320 (14 Channels)...
T4500 with corroded battery contact- How do we clean / fix issue?
A fingernail file, the cardboard/sandpaper kind is the best method. Don't use any solvents. Once you have the corrosion mostly cleaned away, use a pencil eraser to gently clean the rest.
Best regards.
Aug 20, 2011 | Motorola Talkabout T4500 (7 Channels)...
How do I change the channel on my T5320 2way radio?
With the radio on press the MENU button. The current channel will begin to flash. Use the + or - button to change the channel while it is flashing. Press the PTT button to lock in your selection.
Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/T5300_T5400_User_Manual_E.pdf
Aug 04, 2009 | Motorola Talkabout T5320 (14 Channels)...
Turning unit on
It sounds like you may have internal corrosion damage, possibly from the battery situation or from having been damp at some time. If cleaning the battery contact with a pencil eraser doesn't do the trick, you are out of luck. This model is not repairable, as parts and schematics are not available, it would need to be replaced. Here is a link to the owners manual http://www.usersmanualguide.com/motorola/2-way_radio/t6210
Sorry we did not have better news.
Oct 16, 2008 | Motorola Talkabout T6210 (14 Channels)...
Hello Blindmaster,
Best Regards,
Agent Ken
Go Ahead. Use Us.
Mar 31, 2008 | Motorola TalkAbout T5530 2-Way Radio
Motorola Talkabout T5320 (14 Channels) 2-Way Radio Logo
267 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Muntejaya Ginting
Muntejaya Ginting
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
