Question about Refrigerators
Why isn't the fridge cold and making noise?
The freezer is fine
Posted by sheila hegarty on
John Tripp
  • Refrigerators Master
  • 4,656 Answers
What is the model number of your fridge? You either have a defrost problem or the vent is controlling the fresh food section temp correctly. Look onto the rear wall of the freezer to see if there is a layer of frost buildup.
APPLIANCE 911
Why isn't the fridge cold and making noise? - 25975095-l4ubdsyr2pjvirezq5lxi0n2-5-0.jpg
Posted on Nov 23, 2015
Samsung srs585hdis side by side fridge freezer
The cold control inside the fridge may be defective. Hmmm...wonder why Samsung did not mention that as part of basic troubleshooting? If no adjustment of the cold control yields results, chances are it is defective.
Oct 22, 2013 | Refrigerators
Fridge isn't cold. Freezer is cold but frosting up
Is the fan in your freezer working? Make sure the door switch is pressed in when checking as it cuts the fan out when the door is open. Does it have a manual defrost timer?
May 13, 2013 | Refrigerators
My GE model GSH25JFTCBB side by side is not cooling in the fridge side. Freezer seems to be doing fine. What could be wrong
you could have a defrost problem,a bad damper,bad computer board.first thing,open the freezer door,do you hear the fan blowing in there?you should,if not the evap fan motor is bad,if it's blowing touch the back inside wall of the freezer to see if any frost or like snow is on it,from the bottom up in the freezer remove the second bin of food and touch the back inside wall with your hand,if it has frost or snow you have a defrost problem,bad defrost thermostat,heater,sensor or board,if there isn't anything on the wall then you have a bad damper,all that happens is the evaporator coil in the freezer gets cold,then the evaporator fan in the freezer blows the cold air over into the fridge section,you have a damper in your machine that opens and closes when it's cold enough or when it needs to get colder,the door on the damper isn't opening to let the cold air in when it calls for cold air.if you can write back and let me know what you find and hopefully we can get it fixed.
Sep 15, 2012 | GE Refrigerators
The freezer works fine; the refrigerator isn't cold.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Aug 30, 2011 | Refrigerators
Freezer appears to be working, but not the refrigerator section - at most that will only get to 50 degrees. Manually switching to propane makes no difference.
Sounds like your cooling fan is out. If the freezer is fine and the fridge isn't, then the cooling fan isn't blowing the cold air the the fridge. Or you could have ice obstructing the airflow.
Jul 01, 2011 | Refrigerators
I have a Baumatic fridge/freezer the fridge is not cold even on maximum setting the model number is BRB2713 please can you suggest what the problem might be
First check the simple things. Check to condenser grill and make sure the air flow is not blocked by lint, etc. And then make sure that nothing is blocking the cooling tubes between the freezer and refrigerator. I think the Baumatic has a fan pulling the cold air up from the freezer compartment into the fridge, if that isn't working, the freezer would be fine, but the fridge would be to warm.
Jun 03, 2011 | Baumatic BR22 8A Bottom Freezer...
I have a 5 yr old side by side fridge. just a couple of days ago I noticed that temp. in the fridge was way too warm. Freezer is fine, but when I felt for any kind of cool air circulating into the fridge...
frost on the coils means the compressor is working and it is making "cold" if the cold isn't getting to the fridge side the fan the brings the cold air to the fridge side is ethier blocked off or not working. If you have a small thermomator use it to check the fridge side apx 38 to 40 degrees is the "food zone". the fan is usually not to expensive and often not that hard to change. there is a timer that defrosts the coils usually about once every 24 You may see a small knob on the defrost timer. watch its position over several hours and you should see it move position. if it doesn't move then the defrost timer is faulty. the most expensive part of the system is the compressor and it sounds like that part of your system still functions. If the freezer is getting plenty cold but the fridge part is not cooling off you have an air flow problem. It is not uncommon for these fans to make noise and then fail altogether.
Apr 21, 2011 | KitchenAid KSCS25FKSS Side by Side...
Fridge and Freezer not cold, compressor not coming on
these are 2 different things.check the light switch. also check cold-control, defrost timer, relay on compressor.
May 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
john h
