Question about Janome Sewist 525S Mechanical Sewing Machine
Machine seems to be set up correctly but won't stitch. What do I need to do?
My machine is not stitching. I have it threaded correctly, bobbin is in correctly & feeder foot is pulling material through. Any ideas why it won't stitch?
R.A. Ellis
  • Janome Master
  • 12,731 Answers
If, as you have noted, this is a mechanical machine, my suspicion is that it has not been cleaned and oiled recently and possibly the old oil has solidified preventing the parts from moving.
Here is a web site that may be helpful:
Janome Domestic Sewing Machine Maintenance
You may not need to go to the extent of removing parts and soaking them in cleaner, but certainly cleaning the dust & lint and then oiling with a fresh good quality sewing machine oil may be the ticket to your resolution.
Posted on Nov 22, 2015
5 Related Answers
bargainbox
Hassy
  • 1388 Answers
SOURCE: My Janome my excel 23x
Ensure that all is clean and free of lint jams....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tension to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Apr 25, 2008
Anonymous
  • 35 Answers
SOURCE: Thread tension?
I own this little gem of a machine. It definitely sews a perfect stitch. I'm assuming you own the green 3/4 size machine as denoted by your product number. The half size blue one pictured is incorrect.
Anyway, this machine sews a perfect stitch, due to the oscillating bobbin. Most sewing machines with rotary (drop in) bobbins don't have an easily accessible bobbin tension screw, which means your fabric is usually slightly puckered. Fiddling with only the upper tension helps very little. This frustrates me to no end for sewing long curtains, clothing side seams, etc. Wrong tension causes them to hang with puckers, making them look awful. With the Hello Kitty 3/4 size Janome, there is a screw on the bobbin case which allows you to adjust for every thread diameter perfectly. Always a perfect stitch, if you take the time to adjust this screw.
To adjust the bobbin for a perfect tension, load the bobbin into the bobbin case and thread it through the guide. Holding only the thread between two or three fingers, let the bobbin case dangle below. This will be slightly difficult, because the bobbin will want to fall out of the case. Don't worry, just don't move it around too much and it will stay in long enough for this test. If the metal bobbin case slowly drops lower, unwinding thread as it goes, the thread is too loose. Tighten the screw on the side of the bobbin case a little (about a quarter turn.)
If the bobbin case seems to be dangling firmly, give the thread a gentle tug, lifting up fairly quickly. If it doesn't release a couple of inches of thread, it's too tight, loosen the screw. You know the tension is perfect when a quick, light tug of the thread releases a couple of inches of thread.
Posted on Aug 16, 2008
Anonymous
  • 35 Answers
SOURCE: material doesn't move
Are the feed dogs engaged? Janomes usually have a feed dog sliding switch, either on the back of the sewing machine at the bottom, or behind the accessory case. Be sure the check it out. Hope this helps!
Anonymous
  • 111 Answers
SOURCE: my machine is not stitching
needle in backwards?
Posted on Jun 13, 2009
rochelle0099
Rochelle Gross
  • 5 Answers
SOURCE: no stitch happening
May sure you are using the correct size of needle and thread suitable for the fabric. make sure the thread in the bobbin and the needle is of the same weight or size. Make sure the needle is changed often - after the completion of an garment. After much use the needles become blunt and cause problems with your stitches.
Also, if the bobbin is jamming that is normally because the machine is threaded incorrectly, or the bobbin case thread is wound unevenly, or the bobbin case is not put in properly.
Try this! Just stop for a while, give yourself a few minutes to relax. When you return pull the User's Manual and slowly go over the instructions, especially the "troubleshooting" section. Also, rethread the machine and the bobbin case by carefully following the steps in your User Manual. I have found that it helps me tremendously when I have problems. Hope it help. Happy Sewing
I have similar problems
Posted on Aug 02, 2009
Testimonial: "Thanks, and after having a few days break, my machine seems to be nearly back to normal, it is working on normal cotton but not on stretchy material."
Where can I get directions for free motion quilting on my triptonic 2030. I am having trouble with the tension and bobbin stitches are awful.
For FMQ, make sure you have a darning or FMQ foot for your machine. You must use this foot because it is shorter than other presser feet so it does not press down on the fabric. You need to be able to move the fabric freely under the presser foot. When threading your machine, ALWAYS RAISE the presser foot so the thread will seat properly in the tension disk. The presser foot is ALWAYS lowered when FMQing or the tension will not work. To set the tension, test on some sample quilt sandwiches made with the same materials you will be quilting. Be sure to use a brand new quilting, microtex, or top stitch needle in your machine. Skipped stitches generally indicate the needle is dull, bent, or otherwise damaged. Test your stitching on the test sandwiches and adjust the top tension until the top and bobbin threads meet in the middle of the fabric (Increasing the top tension pulls the bobbin thread up. Loosening the top tension allows the bobbin thread to pull the top thread down.) Depending on your thread weight, you may need to adjust the bobbin tension, but do that ONLY if you cannot get the top thread to pull the bobbin thread up into the sandwich. (However, remember that if you adjust the bobbin case, it may not work properly when you go back to regular sewing.) I actually bought a separate bobbin case that I have adjusted only for FMQing on my machine and I use it only for that purpose.
Understanding Thread Tension on Your Sewing Machine
May 31, 2018 | Sewing Machines
Adjusting top and bottom stitches...
the stitch length is set by the amount the foot pulls the material through
adjusting the needle thread tension is the main adjustment to ensure that both threads meet at the center of the materials being sewn
Mar 10, 2017 | Sewing Machines
My Bernette 715 isn't picking up the bobbin thread and is getting jammed. Any ideas what's wrong?
First thing to always try: Install a brand new needle. A dull, worn, or bent needle will cause great frustration. It is also the least expensive resolution to most problems.
Second: Remove all the threads. RAISE the presser foot. Rethread from the beginning making sure it is threaded correctly.
Pull up the bobbin thread before beginning to stitch and hold the thread tails in the left hand while slowly taking the first few stitches:
How and Why to Bring up the Bobbin Thread
If still having issues with not pulling up the bobbin thread, the needle/hook may be out of time.
Sewing machine won pick up bobbin thread hook timing fix
Feb 06, 2016 | Sewing Machines
Top thread too tight. Bobbin thread too loose. Bobbin thread bunches up underneath material. The feeder teeth can not feed material through
first thing first - thread inside bobbin should be tightly wound in. Insert bobbin into bobbin case and thread through slot and under the spring. Spring has small screw which regulates the tension. Hold the thread like yo-yo and jerk a little down-up. It should drop just a little (not run down) - that is usually required bottom thread tension,
if not, regulate with the screw. Set top thread tension 3 and sew. If still looping under, increase the top tension higher till the looping disappears. .
Nov 03, 2015 | Sewing Machines
How do I set a straight stitch? What is causing the top thread to break?
You do not say which machine you have. As for a straight stitch, make sure the needle is central and not in zig zag mode.
The thread can break for several reasons, such as. Incorrect tension.
:Wrong thread for the material.
: Thread in bobbin different from the top thread.
:Old thread.
: Not threaded correctly.
: Needle not inserted correctly, or incorrect needle.or the thread could be wound around the spool holder pin,
Try removing the spool and turn it around.
Hope this helps.
Mar 02, 2015 | Sewing Machines
Having a problem with tension not stitching correctly what can I do to fix it
Tension depends on so many things. Material thickness, right size needle, thread,bobbin etc . If it is none of these things then you need a technician.Best wishes
Jan 24, 2015 | Janome Memory Craft 9000 Computerized...
Thread in bobbin assembly catching.
Could bee a few things, need a size 14/16 in needles. LONG stitch length. Also make sure you the threads in the top tensions correctly ie: one thread in each disc.
Aug 16, 2014 | Sewing Machines
I just bought a singer stylist 9100 and its driven me to tears. The bobbin thread keeps couching through the top of my quilt, pulling the top stitches into a tight blanket stitch looking mess. I have...
Suggest you check your bobbin tension, pull the bobbin thread and if you feel it too loose, most likely bobbin thread not threaded correctly into the bobbin case tension plate. Do refer to your manual if you have one.
Jul 18, 2013 | Sewing Machines
Singer ce100 is skipping stitches when needle is in center position
You don't say what you are sewing so I'm going to give you general answers in hopes it helps.
1. Needles: There is no such thing as a universal needle. Make sure you are using the proper needle for your fabric. This goes for thread too... make sure it's sized for the needle.
2. Make sure the bobbin is threaded correctly (poorly wound bobbins will cause problems too)
3 Improperly threaded machine. Make sure you area threading it correctly with the foot in the UP position.
4. If you are a material puller... shop it. It is never good to pull your fabric through the machine as you sew.
5. Stitch length. simple rule: Fat fabric.. long stitch, fine/thin fabric short stitch.
I'm not familiar with your futura abut I've noticed new home machines take a way presser foot pressure adjustments... which can cause issues too.
Mar 13, 2013 | Singer CE-100 Futura Computerized Sewing...
Top thread will not pick up bobbin thread makes a big loopy mess
This is sometimes caused by the upper thread not threaded correctly. You need to thread it first with the pressure foot in the up position. You need to "floss" the thread into the clear plastic guide as this is where the tension is. The tension should be set to E for embroidering. Also make sure you get the bobbin thread in the slot on the bobbin case. Also, lower your pressure foot before you begin embroidering. Hope this helps!
Sep 20, 2009 | Singer CE-100 Futura Computerized Sewing...
Janome Sewist 525S Mechanical Sewing Machine Logo
80 people viewed this question
Top Janome Sewing Machines Experts
Irene Tulloch
Colin Stickland
Colin Stickland
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
