Error Code E71 - Outlet Control Thermistor open circuit -- Outlet Control Thermistor or wiring defective.
Check resistance of Outlet Control Thermistor, and check wiring for open circuit. Resistance should be between 4.9K Ohm and 6.2K Ohm at room temperature (68-77° F or 20-25° C). Replace Outlet Control Thermistor and/or wiring and retest.
Consult video below for instructions
https://youtu.be/hcKHCzuDvMQ
SOURCE: how to replace fuse dryer frigidaire affinity
If it is like any other frigidaire dryer it is mounted on the upper right hand corner of the rear bulkhead.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: have a frigidaire affinity electric dryer that doesn,t heat
check your heating element or the thermal fuses located on the back wall the side of the heating element can and the plastic blower ducting
SOURCE: My frigidaire affinity dryer is not heating up but
If you have a gas dryer.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting Electric Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
