You should have two Yellows
1999 Chevrolet Silverado Stereo Wiring
Constant 12V+
Orange
Switched 12V+Yellow
Ground
Black
Illumination
Gray
Dimmer
Brown
Antenna
Right Window Trim
Front Speakers
6 1/2" Doors
Left Front (+)
Tan
Left Front (-)
Gray
Right Front (+)
Light Green
Right Front (-)
Dark Green
Rear Speakers
4" x 6" Side Pillar
Left Rear (+)
Brown
Left Rear (-)Yellow
Right Rear (+)
Dark Blue
Right Rear (-)
Light Blue
https://www.google.com/search?q=1999+chevy+silverado+stereo+wiring+diagram+color+code
There may be a problem with the batterie connectors on the back, make sure they are clean. Also, you might buy the wireless accessory set, which comes with chargable batteries and the charging cord, with which you do not need batteries, and might bypass the problem you have.
hi i had same problem,download update service from se e follow the instruction,its free and 100% working for me
make swure that the battery is full charge b4 the up date
if ur phone wen u charge seem to no charge actioly is charging!
give a try
There is a small green 4x4 light that comes on when you have the key in at the heater plug position before starting if its not on then a fuse has blown .
The battery probably needs charging. The camera will automatically shut down if the battery is going flat.
With the Exilim you need to make sure that you don't overcharge the battery by leaving it permanently docked in it's little docking station - this can damage the battery. There is an LED on the docking station which shows the status of the battery. Red is charging, green is fully charged - take it off the docking station.
