Question about LG 32LH20 32 in. LCD HDTV
I need replacement screws for the back, (mounting and/or stand) I dont have time to order them online, does anyone know the size for a hardware store purchase? They are pretty thin.
5 Suggested Answers
MNfisherman
Nate Stansfield
  • 11896 Answers
SOURCE: Need mounting bolts
lg company or go to hardware store and get the biggest bolts that will fit in the holes. Otherwise you may be able to purchase them on ebay.
Posted on Jul 09, 2009
SOURCE: Lost back stand screws for the 37/42lg50
I had sold the stand with screws just two days ago...would have gone to measure it for you, but it's gone...very sorry :-(
However, you can still go to the nearest Home Depot, Ace Hardware or whatever your local hardware store is and get a few sample bolts that help you find out what do you need.
Note they may be metric or enlgish system.
Another thing you can do is search on eBay for others who have the stand and ask them to measure the bolts for you.
Posted on Jan 20, 2010
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: i have a tv stand but i ned the base screws i dont
Metric screws either M5 or M6, get them at HD or LOWES for about 35 cents each so you try a lot of different length.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Posted on Aug 13, 2010
SD Tech
SD Tech
  • 14553 Answers
SOURCE: I need to know what size are the screws for the tv
I found the owner manual online but of course it does not have the info you want.
Suggestion is to call LG customer service to see if they will help you.
Posted on Jun 02, 2012
SD Tech
SD Tech
  • 14553 Answers
SOURCE: I would like to remove the pedestal or stand from a LG 42LG70 TV because I want to place the TV on a wall mount.
Usually the safe way to do this is look first at the owner manual but lay set face down on a padded surface so all weight is on the frame around the screen and no weight on the screen itself, exert no downward pressure in that position or screen may be damaged.
Usually pedestal is secured by 4 or more screws that may require the back cover of the set to be removed first, to get at---a careful look with it face down will show if part of the pedestal is under the rear cover of the set or not.
Posted on Dec 18, 2012
Need to know TV Stand Screw sizes
To know more about this, you have to download the repair manual to this set. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 03, 2014 | Toshiba 47TL515U 47 3D LCD TV
Need screw size for stand
Take the Stand to the hardware store and have them try a few sizes that fit. You need Machine Screws and who knows what length?
Jan 05, 2014 | Hanns.G HL269DPB Black 26" 5ms Widescreen...
Mount screw size
You will need metric hardware (M4, M3, etc.) but you also need to know the length in millimeters to adequately secure your TV. I can't believe that Hitachi cannot supply this basic information, but then again...
Dec 20, 2013 | Hitachi P42H401 42 in. Plasma HDTV
TV Stand Screws
If you still have the manual or know the manufacturer you might want to try giving them a call. They'll know what size screw was used on that model tv stand. Otherwise, measure the insides of the holes and go to a hardware store; they should be able to help you find the right one. Just make sure they are not too long. Screws are pretty cheap, so I'd suggest buying one of a couple different sizes to try out. They should fit snugly in the hole, but should not split the wood/plastic. You'll want to get four of the same size washers and nuts as well once you know what kind of screw you need. That way they won't loosen. :)
May 18, 2012 | Emerson LC320EMXF 32 in. LCD TV
Hi there What size screws do I need to fit the stand to my Evotel tv - ELCD26DUSBHD. Have been given the set second hand with stand but no screws. Don't know where to start to get the right...
Look on the back of the set around the edge. Remove one screw and see how it fits in the position for holding the stand. If good then take the screw to a hardware store or home center store and get all you need. It will most likely be metric. If the screw was short, then get the length you need.
Replace the original screw.
Mar 03, 2011 | Televison & Video
There are no bolts to mount my Samsung Series 6 to my TV Stand
YES TAKE THE SMALL BOLTS WITH YOU AND GET LONGER ONES
Aug 24, 2009 | Samsung Televison & Video
Need Screws for SOVA LCD TV
i need a borad for my sova 32' lcd tv
Mar 26, 2008 | Sova DSV32P112 32 in. LCD Television
Polaroid TV
You are correct. Polaroid does not make the screws available. You will have to obtain locally, per Polaroid.
Mar 05, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Security torx screws
Go to a local hardware store, and ask them for a TORX screwdriver set.  The screws come in a large variety of sizes, and buying a set is the best way.  Make sure that at the base of the driver head it has a small hole for the security nib the screws have that prevents most ordinary screwdrivers from oppening them.
Jan 11, 2008 | Microsoft Xbox 360 Console
LG 32LH20 32 in. LCD HDTV Logo
73 people viewed this question
Ekse
RONALD CARTER JR
