Question about Amazon Kindle 1
Power slide switch not turning it on
When you slide on of swith the kindle dose not turn on
Posted by Buster Anderson on
4 Related Answers
MiB8888
  • 457 Answers
SOURCE: cannot wake up kindle even after sliding power
Try to slide and hold the power switch for about five seconds, until after the power LED behind the power switch blinks three times.
Posted on Dec 31, 2010
Nick
  • 51 Answers
SOURCE: I still can't get my Kindle to turn on even after
First call amazon customer support! They are really good at helping you get your kindle back up and running.
A couple questions to ask yourself Is the kindle fully charged? There might only be enough power for the green LED and not the actual kindle!
If this is your last resort:
I have never done this, and it would certainly void your warrant but I am told that there is a reset button underneath the cover of the kindle...
Posted on Mar 01, 2011
jas247
Jas Barinaga
  • 844 Answers
SOURCE: my kindle won't wake up when i slide the power
Welcome to FixYa.
1. Make sure that your Kindle is charged properly.
2. Unplug it from the power source if it is plugged in.
3. Slide and hold the Power switch for 15 secs. then release.
4. Note that the Kindle screen will go blank for about 30 secs. while it restarts.
Thank you for using Fixya. Have a great day.
Posted on Jun 29, 2011
jlovesabu
SOURCE: How do I unlock my
I forgot my password for my amazon kindle
Posted on Sep 01, 2011
Reset forgotten password kindle touch m/o:D01200
  • Hold the power switch for twenty seconds. You will need to slide the power switch along and hold it for twenty seconds before releasing it.
  • Your reboot screen should appear when you release the power switch.
  • Give your device time to reboot for a minute or two.
  • Turn the Kindle Fire HD back on.
  • Mar 04, 2018 | Tablets & eReaders
    My kindle fire won;t let me turn pages or change any thing
    Soft Reset:
    1. Hold the power switch for twenty seconds. You will need to slide the power switch along and hold it for twenty seconds before releasing it. ...
    2. Your reboot screen should appear when you release the power switch.
    3. Give your device time to reboot for a minute or two.
    4. Turn the Kindle Fire HD back on.
    kindle fire Google Search
    Nov 30, 2016 | Tablets & eReaders
    Kindle will not turn on even tho its bee charging 5 hours
    Soft Reset:
    Jan 01, 2016 | Amazon Kindle Fire HD
    How can I unfreeze my kindle fire ?
    Soft Reset:
    Jul 27, 2015 | Amazon Kindle Fire HD
    It will not power up. was on the charger most of the day.
    To wake up or turn on your Kindle, slide and release the power switch again. If your Kindle does not power on or is unresponsive during use, try resetting the device by disconnecting your Kindle from any power source, and then sliding and holding the power switch for 15 seconds before releasing.
    Mar 22, 2015 | Amazon Kindle Fire HD 8.9"
    My Kindle Fire HD won't turn off. I was watching a movie on Netflix and the picture just froze
    Turning Off the Kindle
    Quickly sliding the power switch on the Kindle enters and resumes sleep mode. If your Kindle enters a non-responsive state when sliding the power switch, you've likely entered sleep mode. Try sliding the power switch and holding it for four seconds to shut down the device. If it still does not shut off, you may need to reset the Kindle.
    Resetting the Kindle
    The power switch also serves to reset the device. Before resetting the device, disconnect it from any power sources, such as an AC outlet or your computer's USB connection. Sliding the power switch and holding it for 20 seconds forces the Kindle to reset and power down. However, a nearly depleted battery may prevent this action. If the Kindle still doesn't shut off, try charging it for several hours and resetting it again.
    Mar 17, 2015 | Amazon Kindle Fire HD 8.9"
    Kindle light is orange when I charge but even after of hours of charging continuous efforts to turn on Kindle, it won't turn on.
    Try to slide and hold the on switch until after the power light blinks three times (should happen after a little more than 5 seconds). Release the switch after the blinks and the Kindle should start up.
    This is only necessary if the Kindle was switched off by the same method before, or if the battery was completely drained. A short nudge of the power switch merely puts it in and out of a power-saving sleep mode, the prolonged hold really cuts / reinstates power.
    Jul 16, 2011 | Amazon Kindle Wireless Reading Device
    How do you unfreeze a kindle screen?
    1. Unplug Kindle from power adapter or computer.
    2. Slide and release the power button. The LED light that surrounds the power button will display green for two seconds.
    3. Shut down Kindle by sliding and holding the power button for five seconds. The LED light will blink three times. Wait for the screen to go blank, then release the power button.
    4. Turn on the Kindle by sliding and releasing the power button.
    5. If Kindle is still not working, you can perform a hard reset by sliding and holding the power button for 15 seconds.
    6. If Kindle is still unresponsive, try charging Kindle before trying to restart the device once again.
    7. Make sure you have the latest software version available installed on your Kindle. The latest version is available here: www.amazon.com/kindlesoftwareupdates
    If you continue to experience problems, please contact us.
    ^ The above information, and much more is found on Amazon's kindle troubleshooting section. The link below will take you there in case you have any further problems.
    http://www.amazon.com/gp/help/customer/display.html?ie=UTF8&nodeId=200510540
    Hope this helps ! :]
    Mar 12, 2011 | Amazon Kindle Wireless Reading Device
    My Kindle 3G seems to have frozen.
    Amazon recommends the following steps. As I'm sure you have already tried the power switch, try starting from Step #5 to do a hard reset on your Kindle.
    Source: Amazon.com
    Please let me know if I can assist you further.
    Regards,
    KYTechnology
    Mar 01, 2011 | Amazon Kindle 3G
    Amazon Kindle 1 Logo
    Top Amazon Tablets & eReaders Experts
    Jax Planet
    Jax Planet
    Sheldon Dedek
    William Alequin
    Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
