Question about Mitsubishi WD-73737 73 in. HD-Ready TV
I have a 73" mitsubishi tv and it keeps going to a screen that says it has found a new input when I have not connected anything
Posted by Richard Coulombe on
3 Related Answers
abhishek33
ABHISHEK.C
  • 1239 Answers
SOURCE: Mitsubishi WD 52525 blue screen on all inputs
Hi and welcome to fixya, it is the colour wheel problem,,,,,,,,,this is common problem please check it ...it may be also cathode ray tube... thank u.........
Posted on Jun 03, 2009
caroldon
  • 17130 Answers
SOURCE: Mitsubishi T.V WS-55815 How to go INPUT , NO
Please check with your remote , the input or video 1 will be found on the source or menu selector which can be scrolled with a view on the display.- on screen.
Check this out.
Posted on Oct 12, 2011
  • 18455 Answers
SOURCE: My 73 in Mitsubishi tv wd 73 c10 has a dark picture buying a new lamp would that fix the problem.
The first thing to do is clean it. There are mirrors and lenses that you need to check to see if they are dirty. When a bulb gets to the point that it might fail, it usually gets brighter. Now for the bad news. The part that is bad if the set is clean, costs 636 dollars.
http://www.tvserviceparts.com/cgi-tvserviceparts/sb/productsearch.cgi?storeid=*20aab4584c1a864062e01c3c70e68e24afb3&search_field=wd73c10&search_submit.x=31&search_submit.y=2
Posted on Sep 25, 2015
Why my tv won't stay on ?
Check your input source. TV is coming on and switching to an input where the source is not on
Sep 26, 2014 | Mitsubishi WD-73737 73 in. HD-Ready TV
SPEAKER PROBLEMS
If you are coming out of the cable box then you need to run a pair of audio feeding the audio to the tv. The other thing to look at is that you have the audio and video connected to the same input on the tv.
Nov 18, 2013 | Mitsubishi WD-73C9 73" DLP TV
Check this out.
Sep 25, 2011 | Mitsubishi WS-55815 TV
I have owned my Mitsubishi WD-60C9 for about 1.5 yrs now with no problems. I recently purchased a new Onkyo HTIB to utilize the HDMI connections on my TV. Everything worked fine for about 3 weeks but...
First thing I would rule out is the firmware version of your TV. The newest version of your firmware is version 11.03. This newest version may be able to fix this problem. You can download it from Mitsubishi's website and there will also be a set of instructions along with the download. These are very important steps that you need to follow to repair your TV correctly.
Jul 18, 2011 | Televison & Video
The "new device found" screen keeps popping up
Inspect for damaged pin on INPUT 1 socket. (left most of the three HDMI connectors)
A quick pull on the cable can damage the pins.
=== If you see mis-aligned pins then please power off the set before making corrective action. ===
============== Here's a textbook instruction from Mitsubishi
If the New Device Found Screen Displays No HDMI Control Option If the New Device Found screen shows no option for HDMI Control, one of these conditions applies: • HDMI Control is turned off in the menus of the new device Action: a. Highlight EXIT and press ENTER to close the New Device Found screen. b. Display the device's setup menus and enable the device's CEC capabilities. c. Wait for the TV's New Device Found screen to appear again. d. If the New Device Found screen does not appear, power off the device. Power on the device and wait for the New Device Found screen to display with the HDMI Control option.
Next time you see the NEW DEVICE FOUND screen pop up.
Toggle the CEC field (on the right side of the pop up) to OFF.
Jan 05, 2011 | Mitsubishi WD65737 65" DLP TV
Replacement lenticular screen for vs6041 60 inch mitsh
we recently cracked our lenticular screen on our 73 in mitsubishi i called the manufacturer and they said they no longer make them. so i looked thru websites to see if i could find some one with a 73 in tv or bigger that they were no longer using or didnt work and i found a guy on www.ksl.com that had an 80 inch tv and we went to go pick up screen cut it to my tv size and it worked!!.
Jun 24, 2008 | Televison & Video
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Mitsubishi HDMI connection trouble
I have the same issue with my 73". Rather then going over all of my connections and equipment I'll just say htat I feel your frustration. I have been on the phone with Mitsubishi directly and it appears as though they have a free software upgrade that should address this problem. If you call 1-800-332-2119 and press 4 in the menu you will get someone to help you. Be patient. They will make you go through all of the fixes that you have already tried. They will mail you a flash drive that goes right into the front USB port of your TV. I hope this is of help. Good luck.
ret4good
Jan 04, 2008 | Mitsubishi WD-73833 73" HDTV
Mitsubishi WD-73737 73 in. HD-Ready TV Logo
81 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
