Tried alignment & cleaning printerhead
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
SOURCE: HP Photosmart 8250 ejects blank page at beginning of print job
I know your model is the 8250, but if you follow this video it should give you same desired result. When you go to chose the printer it should be the 8200 series and same for the driver. Hope this helped!
SOURCE: hp officejet 6110
If machine does not print the colors it cannot align. Try changing the color and try again
SOURCE: HP 2410 photosmart will not align after changing ink cartridge
I have the same problem. I can't tell you how to fix it as my printer will no longer align, but to bypass the align page message to get to setup you have to hold down the setup button then press up.
SOURCE: hp 8250 ERROR 0xc18a0206
Peggy,
This is an ink cartridge problem.
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
