Question about Rival VS107 Seal A Meal Vacuum Food Sealer
Do they make special bags for this unit - Rival VS107 Seal A Meal Vacuum Food Sealer
Posted by Chuck Pugh on
Kelley Hopper
  • 67 Answers
They do! You can get them on the Seal-A-Meal website or even on Amazon. Here's a link.
Vacuum Sealers Accessories
Posted on Nov 22, 2015
Where is the air bag location?
If the air bag light is on there is a code stored in the SRS restraint module - air bags ! Wiring problem , impact sensor ! First place to start is have the vehicle check for codes . Not with OBD2 code reader., factory or professional grade scan tool . If you have not worked on air bag systems I recommend you take it to a ASE certified repair shop or the dealer . People have been killed by accidental air bag deployment , by not knowing what's up . Takes special tools !
Dec 28, 2015 | 2000 Pontiac Bonneville
Air bag light stays on.read out has service air bag.
If the air bag light comes on and stays on it is telling you there is a problem with the system and the air bag(s) is disabled. Until the problem is fixed, the light will remain on and the airbags will not work. Special software is required to read and reset the airbag system. God-Bless!
Mar 03, 2015 | 2006 Chevrolet Silverado 1500 2WD
How do i change turn signal switch
Not enough info. What kind of car? Is there an air bag in the steering wheel? Does the wheel tilt? You'll need special removal tools to get the wheel off and you'll have to find the special connector to unplug if the wheel has an air bag in it.
Sep 30, 2014 | Cars & Trucks
HOW DOES ONE REMOVE THE STEERING WHEEL!
Hi Stephen, Keep in the fore front of your mind that the steering wheel is fitted with an explosive air bag. The center piece of the steering wheel is removed by removing the fixing screws rom behind the steering wheel. Once those have been removed, disconnect the electrical connections by unplugging and place the unit aside. Behind that is the fixing nut holding the steering wheel. Loosen it and then using a puller remove the steering wheel. Behind the steering wheel is a special cassette which contains a special wiring loom which must be realigned correctly if removed or if a new unit is fitted. Failure to align it will result in it being broken or damaged. Reassembly is opposite. Regards John
May 23, 2014 | 2006 Volkswagen Caddy 1.6
Ignition cylinder replacement
If you have a tilt wheel or have an air bag in the steering wheel you'll need special tools and disconnect the actuating wire to the bag before going after the ignition cylinder. I would let a shop do it because if the air bag goes off the shop will have to eat the cost of a new air bag.
Jan 10, 2014 | 1996 Isuzu Oasis
AIR BAG REMOVAL
Hello: Are you wanting to remove the driver air bag? If so remove the horn pad, that is the drivers air bag, be careful when removing so you don't break the connections for the air bag and horn. You will need a special tool to release the assembly. Tool available at Auto Zone, Advance Auto, or O'Riely.
Jan 10, 2011 | 1997 GMC Sonoma
Need to remove heater A/C dash control , what is proper procedure?
Look at fig. 4 for the heater a/c dash control: HEATER CORE Altima REMOVAL AND INSTALLATION
  1. Position the steering wheel in the straight-ahead position.
  2. Turn the ignition switch OFF.
  3. Disconnect the negative (() battery cable; then, the positive (+) battery cable. NOTE: Wait for a least 3 minutes after disconnecting the battery cables for the charge in the air bag circuit to dissipate before working on the air bag module(s).
  4. Remove the driver's side SRS and steering wheel by removing or disconnecting the following:
    • Lower lid from the steering wheel and disconnect the driver's air bag module connector
    • Left and right side lids from the steering wheel
    • Special bolts from both side of the steering wheel using a tamper resistant Torx wrench (T50)
    • Air bag module and store it face up
    • Horn's electrical connector and remove the steering wheel nut
    • Steering wheel from the steering column using a suitable puller
  5. Remove the passenger's side SRS by removing or disconnecting the following:
    • Glove box door and the glove box
    • Front passenger's air bag module connector
    • 2 special bolts using a tamper resistant Torx wrench (T50)
    • 4 passenger's air bag-to-instrument panel nuts
    • Front passenger's air bag module and store it face up.
  6. Drain the cooling system into a clean container for reuse.
  7. Discharge and recover the air conditioning system refrigerant.
  8. Working in the engine compartment, disconnect the heater hoses from the heater core tubes.
  9. Remove the instrument panel by removing or disconnecting the following:
    • Kick plate and dash side finisher on the driver's side
    • 2 lower panel-to-instrument panel screws and the lower panel on the driver's side
    • 2 lower reinforcement panel-to-instrument panel screws and the lower reinforcement panel
    • 6 steering column cover screws, the covers, the spiral cable and combination switch
    • 2 cluster lid "A" screws and the cluster lid "A"
    • 3 combination meter screws, disconnect the electrical harness connector and remove the combination meter
    • Switch panel
    • Instrument panel lower covers
    • Snap out the transmission shifter finisher (boot)
    • 4 cluster lid "C" screws and the cluster lid "C"
    • 4 audio and deck pocket-to-instrument panel screws and the audio and deck pocket
    • 5 center console screws and the center console
    • 2 center instrument panel screws and the center panel
    • front defroster grilles
    • Front pillar garnish
    • Instrument panel 3 nuts/4 screws and the instrument panel
    • 8 instrument stay assembly nuts and the stay
    • Steering member assembly 5 nuts/1 bolt and the steering member
  10. Remove the air conditioning housing assembly by removing or disconnecting the following:
    • Refrigerant lines from the air conditioning housing assembly
    • Thermo control amp
    • Air conditioning housing assembly
  11. Remove or disconnect the following:
    • Heater unit
    • Heater core from the heater unit Fig. 1: Exploded view of the steering wheel and air bag module 93112gd9.gif
      Fig. 2: Exploded view of the passenger's side air bag module 93112gd0.gif
      Fig. 3: Exploded view of the instrument panel assembly 93112ge1.gif
      Fig. 4: Exploded view of the heater housing assembly and related components 93112ge2.gif
      Fig. 5: View of the heater core and heater housing 93112ge3.gif
    To install:
  12. Install or connect the following:
    • Heater core to the heater unit
    • Heater unit
  13. Install the air conditioning housing assembly by installing or connecting the following:
    • Refrigerant lines to the air conditioning housing assembly
  14. Install the instrument panel by installing or connecting the following:
    • Steering member assembly and the steering member 5 nuts/1 bolt
    • Instrument stay assembly and the 8 stay nuts
    • Instrument panel and the instrument panel 3 nuts/4 screws
    • Front defroster grilles
    • Center instrument panel and the 2 center panel screws
    • Center console and the 5 center console screws
    • Audio and deck pocket and the 4 audio and deck pocket-to-instrument panel screws
    • Cluster lid "C" and the 4 cluster lid "C" screws
    • Snap in the transmission shifter finisher (boot)
    • Switch panel
    • Combination meter, connect the electrical harness connector and install the 3 combination meter screws
    • Cluster lid "A" and the 2 cluster lid "A" screw
    • Combination switch, the spiral cable, the covers and the 6 steering column cover screws
    • Lower reinforcement panel and the 2 lower reinforcement panel-to-instrument panel screws
    • Lower panel and the 2 lower panel-to-instrument panel screws, on the driver's side
    • Kick plate and dash side finisher, on the driver's side
  15. Working in the engine compartment, connect the heater hoses to the heater core tubes.
  16. Install the passenger's side SRS by installing or connecting the following:
    • 2 new special bolts and torque using a tamper resistant Torx wrench (T50) to 11-18 ft. lbs. (15-25 Nm)
  17. Install the driver's side SRS and steering wheel by installing or connecting the following:
    • Steering wheel to the steering column
    • Steering wheel nut and torque the nut to 22-29 ft. lbs.
    • Air bag module
    • New special bolts to both sides of the steering wheel and torque the bolts using a tamper resistant Torx wrench (T50) to 11-18 ft. lbs. (15-25 Nm).
    • Both the left and right side lids to the steering wheel
    • Lower lid to the steering wheel and connect the driver's air bag module connector
  18. Refill the cooling system.
  19. Connect the positive (+) battery cable; then, the negative (() battery cable.
  20. Evacuate, charge and leak test the air conditioning system refrigerant.
  21. Operate the engine to normal operating temperatures; then, check the climate control operation and check for leaks.
Nov 19, 2010 | 2002 Nissan Sentra
I have a 2007 Ford Escape that the airbag light is flashing 1 then 8. It does this a few times, and then stays on. What does this code mean?
I think you might have a bad air bag module or sensor that is usually a problem when the air bag light try checking that and see if it helps
Jan 09, 2010 | Ford Escape Cars & Trucks
How do I work a Salton vacuum bag sealer (Model BS-20)? I can not figure out how to get the air out of the bag.
This style of vacuum sealer has to use a special bag with a " dimpled " surface to let the air escape through the pinch jaws of the vacuum sealer.
The folowing web site has bags and rolls that can be cut ro make any size of bag you require. You can buy on line direct from the manufacturer as well as purchase more industrial vacuum packers
http://www.foodmc.co.uk/Category/113-textured-bags-for-external-bag-machines.aspx
Jun 14, 2009 | Vacuums
Kirby
kirby style 2 bags if it is indeed a bagged unit, some where special order with what is called a shake out bag, if your outer bag has a short zipper with a cloth pocket it is a shake out bag in which you take the assembly loose from the machine and open the bottom of the metal empter and take out side and basically shake out the dirt. and use the pocket to help get out the dirt. but most of these machines did take a style 2 bag in which you unzip the outer bag and pull the paper bag away from the tube and reinsert new one onto tube and finally zip up bag
Mar 28, 2008 | Vacuums
Rival VS107 Seal A Meal Vacuum Food Sealer Logo
831 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Michael Thomas
Michael Thomas
Paul Carew
Colin Stickland
Colin Stickland
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
