Changed battery...No luck
SOURCE: can't get my croton watch to work.
There are a few possible reasons why your watch is not working:
These are the 3 reasons why your watch could not be working. The reason will fall into one of these 3 categories, so I hope this helps!
SOURCE: zoppinni mother of pearl round watch
You just need a new pin which is relatively inexpensive. Any jeweler should be able to help you with this.
SOURCE: just replaced the battery on
If you have had your watch awhile, it probably needs a clean/oil/adjustment. FIne watches need regular mainentance just like a car. Take to a local watchmaker or send to following:
http://www.bulova.com/service/servicecenter.aspx#inside.aspx
SOURCE: I am searching for a
Thanks for contacting FixYa. Unfortunatley I had no luck finding a manual but you could try to contact them at this link:
http://www.chanel.com/apps/contact/html/ecrivez_nous.php?zone_lang=USAEN
Best regards. Jewel
SOURCE: Pulsar Ladies date watch, approx.
It is possible the battery was weak to begin with, have the battery replaced to see if that will cure the problem because this a much cheaper way than the alternative.
