Question about Select Jazzy Used Electric Wheelchair
I replaced batteries in my jazy power chair, and the control light flashes 9 times.
Posted by James haynes on
Scooter Doctor
    Master:
  • Select Master
  • 401 Answers
James,
the flash code for some of the Jazzy's say that your brake solenoid wiring has a problem, check your connections to both sides of the chair. Strege Mobility
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Posted on Apr 29, 2016
1 Related Answer
oregoon
  • 175 Answers
SOURCE: have an Aspire Quicky chair, power light bar on
It's likely after sitting for so long that the batteries are shot. Sealed-gel-batteries should be fully charged, then totally disconnected before storage, and then put back into service within a year, or placed back into the chair and recharged again, and disconnected again.
Test the batteries using a voltmeter set to DCV, in the 20 volt or more range. Put the probes across the terminals. A good 12 volt battery should read in the 12.5-13.5 voltage area. If it isn't hitting those numbers after a charge, it is no good; time to recycle. Your chair takes two batteries, which are gel, Group 22 or Group 24 type and will cost you about $350-$450 for a set. Group 24 will give you the maximum range for this chair.
Posted on Jul 07, 2009
My M41 invacare controller keeps flashing and it flashes 5 times. I don't understand what the fix for this.
If your M41 has the mark V controller that is seen pictured in the stock photo you provided, the 5 flash code is a left park brake fault.
1. Turn off the chair.
2.Disengage the left motor (levers are located in front under the seat) roll the chair back and forth and re-engage the left motor.
3. Engage the left motor.
4. Turn on chair.
If you happen to have the older Mark IV controller (has a toggle switch to turn on/off and three battery lights), the 5 flash code means the chair is receiving high or low voltage from the batteries. I would recommend having the batteries checked.
If the chair stops flashing, you are good to go. If the chair is still flashing, you will need to contact a technician to possibly replace the left brake. I recommend Repair Xpress FixMyPWC com Nationwide service and delivery solution for power...
Jul 15, 2014 | Electric Mobility Invacare Pronto M41...
When I turn my wheelchair on a service indicator light at bottom of joystick blinks 9 times. How do I fix this?
If: Battery indicator flashes the charge level is low
immediately after recharging.
Then it is a. Weak Batteries.
b. Charger malfunction.
c. Electrical malfunction
Solution a.Replace batteries.
b. Replace charger. Contact Dealer/Invacare.
c. Contact Dealer/Invacare.
I got the above from the manual. The link is:
http://www.invacare.com/doc_files/1125085.pdf
Regards
Chellakumar
Jun 13, 2014 | Invacare Pronto M51 Power Wheelchair
I have a Invacare Pronto M51, the chair won't move. When I turn on the joystick, the wrench light flashes 9 times, stops, then flashes 9 times again. Can you tell me what that indicates?
A flash code of 9 indicates a communication fault. What this means is that there is a lack of communication between the joystick and the other electronic component, the controller module. In my experience, the usual culprit is that the charger plug makes bad contact inside the joystick housing causing it to heat up and burn. This can cause components inside the joystick to burn out. The other more common problem is that there is a break in the 4 wire harness going from the joystick down to the controller in the base. Sometimes it is just a matter of unplugging the connector, cleaning it, and pushing it back in. In other cases, the wire has been cut or broken along its length. Look for cuts along the black covering of the 4 wire harness (connecting cable)and twist and tape or splice and solder to repair the wires. These connecting harnesses are so inexpensive it is usually easier to replace, however a quick splice can get you going temporarily. If you smelled burning that would be an indication that the joystick assembly has burned out and I would replace that along with a new harness (connecting cable with a plug on each end) to the base electronic module.
The connecting cables have always been a weak link in this design and have had a history of failures over the years. For this reason I replace both the joystick assembly and connecting cable when servicing. Hope this helps.
Mar 21, 2014 | Invacare Pronto M51 Power Wheelchair
How do i fix the chair when the control flashes 9 times
Typically when a joystick flashes 9 times, it indicates there is a problem with the solenoid brake(s). I recommend contacting Pride Mobility for a Certified Technician in your area to look at this chair.
Jun 19, 2013 | Pride Jazzy Select 6 Indoor Power...
How to reset controller on jazzy power chair
yellow light is flashing and i can't turn chair off. still operates.
Jun 20, 2012 | Pride Jazzy 1103 Ultra Standard Power...
Our church has 2 Jazzy's one is blinking the code all lights flash 7 times the other 9 times all lights flash can not find what I need to do in our book. Can you help is there a web site I can get a...
mtp see the below list
The listed Flash codes are pretty standard and are applicable to powerchairs only not scooters:
1 flash User Fault (do not touch joystick) and turn back on
2 flashes Battery Fault Recharge batteries or replace
3 Left motor fault check connections or replace
4 Right motor fault check connections or replace
5 Left park brake fault check freewheel lever or brake connections
6 Right park brake fault check freewheel lever or brake connections
7 Remote fault check connections and wiring replace remote(joystick) (Check cable to the joystick unplug connector at rear of chair and plug back in then try turning on to see if you are getting same code)
8 Controller fault Check connections and wiring replace controller
9 Communication fault check cable replace (almost same problem as 7) try same fix if doesn't work joystick will have to be replaced
10 and 11 are unusual and will not be seen if at all Hope this helps you
Apr 04, 2011 | Pride Mobility Products Health & Beauty
One red light three green flash when turned on
Your chair has a motor problem. The code does not tell which side it is. Make sure both motors have the brakes in the drive position before turning on the chair. Also check that both motors are plugged into the main control module in the base of the chair.
May 15, 2010 | Invacare Supply Group Invacare Pronto M91...
Chair won't go. Lights flash
Check your freewheel levers. They must be engaged or the lights will flash and the chair will be inoperable. These levers are under the shroud behind drive wheels. (One on each side)
Apr 30, 2010 | Pride Jazzy Select 6 Indoor Power...
Select Jazzy Used Electric Wheelchair Logo
435 people viewed this question
Top Select Health & Beauty Experts
Rob Hill
Rob Hill
Roger Paull III
Are you a Select Health and Beauty Expert? Answer questions, earn points and help others
