Hi Shonda.
the answer will depend a bit on the specific washing machine you have, and on the settings. There will usually be settings of hot, warm, and cold for both the wash and rinse cycle. A hot wash and hot rinse will keep you at the highest overall temperature during the wash.
There are a number of washers that have internal water heaters that can optionally be activated, usually with a panel switch. This lets them boost the water temperature in the event that the water coming from your water heater isn't that hot - say if you've turned the heater down so that kids won't scald themselves at a sink. The heater option, if there, will make the hot water hotter, though you'd have to look in the manual for you particular machine to see how much hotter.
Conversely, if you want hotter water in the machine, you could raise the setting for your water heater, though you should be mindful of whether this will endanger anyone. You'll also use more energy keeping the heater hotter, so bear that in mind.
Hope this helps, and Good Luck!
D
