SOURCE: KEB5247 Kitchenaid built in electric double oven
Yes the inner door glass is a replaceable part and the door will have to be disasembled but not replaced. I can help with sourcing any parts for you since you used a premium post.
SOURCE: MAIN HOUSE FUSES TRIPPED, RESET, OVEN AND GRILL WILL NOT HEAT UP
sounds like the fan element this link will help http://www.ransomspares.co.uk/elements.asp?search_fd6=XOU252
SOURCE: belling oven door not closing fully
Hi. Yes, you will need to replace hinges, and possibly the hinge guides located inside the cookere.
SOURCE: How do I remove the oven element on our Belling
It all depends on whether the scew heads are flat, or have slots for a screwdriver.
If no slots , then you are going to have to access the heater from the rear of the outer rear cover of the oven.
If the screws can be undone from inside, then simply unscrew them, and pull the element out towards you.
Hope this helps.
