It would help to know which make and model your printer is!
If it a Canon, then visit this page for a number of possibilities - but it sounds it could be serious.
Remove All Cartridges. Do whatever is necessary to remove the individual ink cartridges from your printer. In most cases this will be opening the lid of your printer and waiting for the cartridge cradle to move into the correct position.
Remove the Printhead. This is easily achieved in most printers by simply lifting the orange/gray locking lever on the side of the cartridge cradle and then gently lifting the printhead from the printer.
Reinstall the Printhead. Gently put the printhead back into your Canon Pixma printer and lock it into position firmly.
Reinstall All Cartridges. Place all of the cartridges back into the printer and close any open doors. This makes sure that your printer is actively examining the reinstalled cartridges and printhead.
Unplug the Printer. Physically remove your printers plug from the wall and leave it unplugged for 5+ minutes. This allows the printhead to cool and all residual electricity to leave the printer.
Plug the Printer Back.
Do a Nozzle Check or Cleaning Cycle. The B200 error does not tend to occur until your printer actively tries to use the printhead. As such I recommend performing one of these processes in an attempt to confirm the correct cartridge has been replaced.
Steps for 2 Cartridge Printers
Turn the Printer off. When your printer is in this error state it will not let the cartridge cradle within the printer move. However resetting the printer should clear the error message temporarily allowing us to troubleshoot further.
Turn the Printer Back on Again.
Remove the Problem Cartridge. Whilst the Canon Pixma error messages do not tend to specify which cartridge is causing the problem, you should be able to have a rough idea based upon which cartridge was last replaced.
Install a Replacement Cartridge. As the printhead is part of the cartridge, sadly there is no way to stop the B200 error without replacing the cartridge. I would recommend either installing a new cartridge or a previously used cartridge that you know to be functional.
If Necessary Replace the Other Cartridge. If the error persists with the new cartridge, it may be that the other cartridge has developed a fault and is the cause of the B200 support code. If at this point the error remians I can only recommend replacing the other cartridge.
Canon Printer Error B200 usually relates to a printhead problem and an error message code B200 will flash on the Screen. Orange and green lights will keep on flashing 10 times as a sign of this error. Caused by some foreign trash inside the rollers of a printer or due to paper jam in Printer.
Canon Printer Error b200 is a very annoying error. If you are facing the same error check this blog and Just follow the steps which are written on the blog to fix the Canon Printer Error b200. We give online help for Any problem in Canon Printer Errors.
1) The Support Code b200 is an error message that may arise with the text which states "Printer Error Occurred", or "Contact the Service Center".
2) You will receive this message on your printer due to an electronic problem which may arise in the ink cartridges.
3) Open the top cover of your printer. Discard all the cartridges. Get rid of the printhead by lifting the lever which is placed just near the cartridge cradle, then take the printhead from the printer.
4) Re-insert the printhead back into its correct position, and ensure to lock the lever. Insert all the cartridges into their correct position, and confirm that there is no open door.
5) Unplug your printer cord from the electricity board, and keep it unplugged for a few minutes.
6) Let the printer cool down. Plug the printer back again.
The fault in Canon Printer Error Code B200 indicates a defective print head. A print head is a component that directly collects the ink onto the paper from the cartridges, which means it's one of the most critical parts of the printer.
Canon Printer Error Code B200, which can signify a hugely damaging system error, is one of the most feared.
Want to Correct the B200 Canon Printer Error Code?
1. Unplug and leave your printer disconnected for a minimum of 30 minutes.
2. Open your printer's door and you can move the print head so you can reach it.
3. Take off old ink.
4. The complete Canon Printer Error Code B200 solution.
It is referenced on other message boards that the B200 error means "Printhead Temperature exceeded", which can be caused by an ink cartridge running out, yet the printer continues the operation. You could try unplugging the printer for a couple minutes to let it cool down, and try again. If it still has the error, you'll most likely have to send it in for repairs.
Your Pixma ip 4300 error B200 definition: Over-heated print head. It sounds like an: "ut-oh', but not a big deal. The reason the print head overheats? Ink needs to be replaced... Replace the ink cartridge that is low (you should have received that message at least once).
I would shut it down to prevent damage, until you can get the ink cartridge replaced.
The error code is standard for many of the late model MPxxx printers. The B200 error is "Printhead Temperature exceeded", What this means that while you were printing some document, either one or more of the printhead ink wells ran out of ink and the printing continued. Printhing without ink in the wells will OVERHEAT THE PRINTHEAD NOZZLES and can potentially burn the out. The printer has a built in temperature sensor to detect the ambient temperature and to monitor the temperature of the head. This data is always collected and monitored and saved in the EEprom data and the Service Test print data.
If the error will not go away once you have unplugged the priner for at least 5 minutes, then there is the possibility that you have already burnt out the head. Remove the printhead and use a 5x magnification glass to look VERY CLOSE at all of the nozzles to see if you can detect any possible burnt out nozzle.
