What is the true speed (top end) of the 2002 zzr 400 kawasaki
That is so dependant upon "Many Variables!!--If you were shaped like a bullet`weighed no more than 90Lbs & were laying under the paint, with quality high octane rated fuel, without brakes binding , & no accessories like Panniers & the Engine had at least 16,000K'ms Legit on the clock ,& at sea level ( Not High Altitude & on a "moist day" without Pillion Passenger ,& with Engine having Air Cleaners near new,& providing each Cylinder registered similar Compression Pressure , Perhaps 15 Psi & The Engine had correct Viscosity oil , & Drive train was not "MALADJUSTED " this macine , with small tailwind could be expected to top the Ton!---Now, IF YOU REALLY wanted to know just how good KAWASAKI'S earlier prducts were . locate >1974 S3 --2Cycle Triple Fire Breather & Could out accellerate & out run HONDA K1 750/4 --Reason>?"Power To Weight Ratio"--I hope that has been useful!--Whilst I 'm on that aspect, the Triple sounded to be screaming ( As if Ultra High RPM, Not so, it being Clarke cycle ( 2 Stroke , has "power pulse each time piston climbs to Top Dead Centre & the Four Strokes , Rev so much harder, yet do not quite sound so !!---The Mighty Vincent V Twin was an exception though >Guaranteed each Macine would reach 120 MPH 998 CC British, with very short pushrods, & alongside one at The Ton, years pasyt I noted His Tacho was only showing 4,200RPM!--O K -Cheers, Stay Upright", Des
Hows the plug look. Did you do a compression test, and how long has it been since you have cleaned your power valves?
