SOURCE: Rotating the image.
Hi, I am not familiar with that model, But usually if you go into the settings menu you will see settings for the display which may be under "Display" "Rotate" "Keystone" "Flip" That model is made to be mounted upside down so somewhere in the menu there will be a setting similar to those I mentioned that will flip the image.
Hope that helps, Sorry I couldn't be more specific.
SOURCE: how to make image right-side up
instalation properly ,surface of celing not in level ,left side scerew little unscerw problem solved.put some washer&check
DGTEC PR80: 1) Start by turning it on, 2) then click on Menu on the Remote, 3) Then click on "AV" on the remote, 4) once in "AV" mode then click on "FLIP" on the remote which will rotate the picture. Keep clicking "FLIP" until the picture is the best option for you. 5) then click on "MENU" or "RETURN" on the remote and the setting will be saved. 6) do this procedure each time you turn the power or reset the device. Thanks
That's a right tips.....DGTEC
