Question about Clarion Car Audio & Video
How do i get my clarion vz401 too play dvd videos from my USB
Posted by Raylon Morrison on
  • Clarion Master
  • 6,133 Answers
The Clarion VZ401 can only play audio (MP3 or WMA) files from a USB device. This is listed in the manual on both page 33 (USB Operations) and page 46 (Specifications). This unit can't play audio file with DRM and some USB drives may not be compatible with the device. It can play some videos from some IPod/IPhone models with the Clarion CCA-750 adapter. This is a USB to RCA composite stereo audio/video jacks cable. This feature isn't compatible with the Lightning connector or some versions of the iOS operating system. To view any other videos, you need to play them back on a device that can directly connect to the composite RCA audio/video ports (AUX In or AV In).
I hope this helps. The list of compatible IPod and IPhone models is available from Crutchfield on the VZ401 Details tab: http://www.crutchfield.com/S-ix4f1cAUkb9/p_020VZ401/Clarion-VZ401.html . This tab also has a link to the manual; the direct link is http://d2stobyut4u5rx.cloudfront.net/ImageBank/v20150407084800/Manuals/020/020VZ401.PDF .
Posted on Nov 18, 2015
2 Related Answers
smarthome2
Frank Fulton
  • 1114 Answers
SOURCE: clarion vrx485vd wont play videos from iphone when connected
You need a composite video cable to the Clarion Video input. The usual ipod adapter is for audio only. If you have an AV ipod adapter and you still don't have video, the signal is not strong enough for the clarion to see it and you need a 12volt pre amp. you can find them online starting around 25. Hope this helps
Posted on Jun 24, 2009
rusty2c
  • 239 Answers
SOURCE: my clarion VRX486VD will play dvds but not video clips
use nero vision this will work it does the same with mine
pls rate people arnt rating hope this helps
Posted on Aug 19, 2010
Which rca wires are for sub on a clarion vz401 car radio touch screen
I have no idea. Recommend contacting a local car audio professional or Clarion customer support directly here:
https://clarion.com/xe/en/user-support/inquiry/contactus
Apr 06, 2017 | Clarion Car Audio & Video
I calibrated my clarion vz401 wrong now I can't operate from the screen at all what can I do
If all else fails, I recommend contacting a local car audio professional or Clarion customer support directly here:
I trust this information proves beneficial.
Apr 27, 2016 | Clarion Car Audio & Video
Why is the screen not coming on my Clarion vz401 Clarion but I have sound and everything else works
If you have a blank screen while listening to an audio source (Radio, CD, USB, etc.) the interconnecting ribbon cable that goes from the system board to the display module could be damaged/cracked and needs to be replaced.
Mar 24, 2016 | Clarion Car Audio & Video
I Need The Wiring Diagram For The Clarion Vz 401
[PDF]VX401 VZ401 - Clarion
www.clarion.com/br/pt/pdf/VX401_Manual.pdf Clarion Co., Ltd.VZ401. Owner's manual & Installation manual. Mode d'emploi et manuel d' ... Congratulations on your purchase of a Clarion mobile electronic product. We are.
Sep 22, 2015 | Clarion Car Audio & Video
Wiring diagram for clarion vz401
Get the Owner's Manual here.
http://www.clarion.com/ca/en/pdf/VX401_Manual.pdf
The Installation Guide and Wiring diagram starts on page 47.
Sep 09, 2015 | Clarion Car Audio & Video
Clarion vz401 screen white
Awesome!
Mar 07, 2015 | Clarion Car Audio & Video
Where does the phone interrupt wire go to off my clarion vz401?
Don't use it. The brown wire (phone interrupt) is for factory integration with the built in phone on very few vehicles.
Jan 08, 2013 | Clarion VX401 Car Video Player
How do i change the region codes on my clarion vz 401
My head unit clarion vZ401 plays only region 1. I live in Australia and this head unit is now ******** me as all DVDs sold in Australia are region 4. Can some please tel me where to buy a hack cd or add on . Wayne
Sep 17, 2012 | Clarion VZ401 Car Video Player
Clarion vz401 unlock reset?
ok i have a vz401 and it was locked out so what worked for me is.
hold the volume down button then push the power button after you are holding down the volume button.then if you dont know the code put in 4356 it worked for me
Apr 05, 2012 | Clarion VZ401 Car Video Player
Car Audio & Video Logo
437 people viewed this question
Top Clarion Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
