From the main screen of your phone open you menu, then messaging, then messaging settings, then multimedia message, then MMS profiles. from there create a new profile and fill in these settings:
Set Name: Straight Talk Access Name: att.mvno Auth Type: Normal User ID: *leave blank* Password: *leave blank* Protocol: HTTP Home URL: http://mmsc.cingular.com Proxy Address: proxy.mvno.tracfone.com:80 Linger Time: 300 *leave advanced settings alone*
Save your profile and select it using the square on the right of the screen. You should now beable to recive multi-media text messages. Exit out to your phone main screen. Press menu, then Media Net, then Browser Settings, then Browser Profiles, then select the profile named straight talk by pressing the square on the right side of the screen. You should then be all setup to use all forms of data and messaging on your new Straight Talk plan. I hope this was helpful!
Composing Picture Messages
1. On the All messages screen, tap Compose message. The Compose screen opens.
2. Enter the wireless phone number or email address of your message recipient in the To: box. As you enter the phone number or email address, matching contacts will appear on the screen. Tap a recipient or continue entering the recipient's phone number or email address.
Tap the "Tap to compose" text box and then start composing your message.
4. Press Menu and tap Attach.
5. On the Attach window, select Picture.This opens Album to let you attach a picture to your message.
6. When you are finished composing the picture message, tap Send.
To open and view a picture message:
1. On the All messages screen, tap a picture message to open it.
2. Tap the Play button at the right side of a picture message to view it
To reply to a picture message:
2. Tap the text box at the bottom of the screen, compose your picture message (see "Composing Picture Messages"), and tap Send.
Hi it could be telling you that your message memory is low so try deleting some inbox/outbox/drafts and sent messages, it could also be a media message so check if your phone is receiving these as your settings could be wrong if you have not sent or received media messages such as pictures then it could be one of those but your settings are wrong call your service provider and they will send the settings for free
My wouldn't either. I went in to "Menu"- "Messaging"-"Message Settings"- "Multimedia Messaging"- "MMS Profiles". I had 3 choices on the next screen... Since I use AT&T I checked 'AT&T MMS" My other choices were "media Net and AT&T IMS" Media net was checked but after I changed it to "AT&T MMS" I was able to start sending pictures and videos.
Hope this helps.
~CherylofTexas~
You need to use the supplied Sansa Media Converter program to convert and transfer photos (and videos). If you don't have the SMC, you can download the Windows version from http://www.megaupload.com/?d=3IPZO6Q0
It is doing this because most carriers only support 140-160 characters per sms message. Once you are over your carriers limit per message the phone is made to change it from an sms to an mms message. Naturally when you send media it goes through mms so that is the default symbol for mms on your phone. MMS supports up to 1000 characters per a message. So in order to continue using sms you need to keep your messages at 140 characters or less including spaces
