How to Fix Canon Pixma Support Code B200 Error Message
? 3:06
https://www.youtube.com/watch?v=jxhkgrozauY
Mar 5, 2014 - Uploaded by Refresh Cartridges
The Canon Pixma "Support Code B200" error message may also be accompanied by text stating "Contact ..
SOURCE: Ink absorber is full.
Try this:
How to clear E27 Waste ink absorber full
1.With the printer powered off but connected to a power source,
press the Power button while pressing and holding the Stop/ Reset button.
2. When the Power is lit, press the Stop/Reset button two times
while pressing and holding the Power button.
3. When releasing the Power button and the Stop / Reset button (regardless of order),
the printer will move into a service mode. (Waiting for menu selection)
4. When the on/off lights in green, press the Stop/Reset button the
specified number of time(s) according to the function listed in the table below.
(Each time the Stop/Reset button is pressed, the LED lights alternately in orange
and green, starting with orange.)
Note: press 4 times for waste ink counter reset.
The number of the Reset button pressing LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5.Turn off the printer.( it must be turn off) then turn it on again
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: I have a new cannon pixma mp140, paper feed problem
it is problem paper prasser guide adjust or paper feed sensor is missing check it and service it
SOURCE: Cannon mp145 ink absorber full,
Follow the steps below to fix the problem.
1. Turn off the printer (power cable is plugged), press and hold the STOP / RESET then press the ON / OFF
2. Hold the ON / OFF, press the STOP / RESET 2x
3. Release both buttons, wait a minute, and the printer will enter SERVICE MODE
4. The printer will be charging
5. After the printer has finished charging, press the STOP / RESET 4x. (Waste ink counter reset)
6. Each time the STOP / RESET button, light ON / OFF will turn green and orange colors
7. After that Turn the printer off by pressing the ON / OFF (3 times for printers die total) and unplug the POWER
8. Turn the printer back.
Regards,
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
SOURCE: Canon MX860 printer is showing:
It is my pleasure to guide you.
After looking at some information about the printer error and that the error tells you to "contact the service center" I have given you places to contact about this error. Some of the information that I have looked at about the error said that several things can cause the error. I suggest that you contact Cannon through the 'Email Assistance'.
Service & Support
Support Home ' http://usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx860#
Email Assistance ' http://usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx860#
Solutions List:
Contact Canon for B200 error (MX860)
Press ON switch and wait a few minutes before powering back on the device
Good luck and please post back that you are successful, giving thumbs up, or if I can be more helpful.
SOURCE: Canon iP2600 series-USB002 error message "The
You may need to reset your printer by software.
To reset your printer jast go to:Use ip reset software:
http://serviceprinter.wordpress.com/2008/03/26/ip-tool-canon-resetter/
Download canon ip 2600 printer resetter.
Run it on your pc.
And try to reset your printer with the resetter.
Thank you.
