Question about Vizio Televison & Video
Vizio e601i-a3 won't stay powered on
When I press the power on, the Vizio logo dsplays on the screen, but the TV shuts off shortly after the logo. It seems like it is trying to transition from the Vizio logo at start up to the HDMI input when it shuts down
Posted by Ed Carmody on
2 Related Answers
gopakumarg43
  • 76823 Answers
SOURCE: I have a Vizio e601i-a3 TV which powers on and shows vizio symbol fine then The screen starts flickering and power to the tv goes off after about 1-3 mins. Any suggestions on how. I can fix the Tv?
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Oct 12, 2016
gopakumarg43
  • 76823 Answers
SOURCE: My TV has no picture (black screen). I did the flashlight test and can see images. Replaced the power board and still the same issue. Yes I have audio but no video Vizio 60” e601i-a3. Please help.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts./
Posted on Aug 03, 2018
Vizio E601i-a3 does not power on
battery dead or worse 1/2 shorted.
buy one , put it in.
The backlight on my Vizio E601i-A3 is not coming on. How can I tell whether it is the power board or the LEDs themselves?
Vizio had a recall on this model TV resulting from the issue your having, below is a link to the recall. What they said was recently Vizio put up a special bulletin on its website stating a number of its 60-inch E601i-A3 and 70-inch E701i-A3 HDTVs may lose the picture (but maintain audio) due to a bad "chip assembly". The "chip assembly" is actually in the main board, Ive fixed a number of this model TV's by replacing the main however Ive also seen the lamps fail as well so its kind of a guessing game as far as where the issue is at unless you have some high end test gear to troubleshoot the set.
Vizio Issues Recall On Large Screen LED LCD HDTVs
I have a Vizio E601i-A3. The "Vizio" emblem does not light up and the screen does not light up. Is it most likely power board that needs to be replaced?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
1helpful
Vizio Model E601i-A3 not staying on
Shorted main board would be the next issue. Not worth it to repair, replace it.
How to diagnose television fault?
diagnose television fault Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.avsforum.com/forum/167-plasma-flat-panel-displays/1491814-common-diy-diagnosis-repair-info-plasma-led-lcd-ccfl-lcd-tv-sets-monitors-display-devices-mostly-power-supply-repairs.html
How to Diagnose TV Problems
http://www.repairfaq.org/samnew/tvfaq.htm
Latest Repair Tips
Vizio E601i-A3, blue vertical line on screen in center.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Connect Dell Inspiron 6400 to VIZIO E601i-A3 60-inch 1080p LED HDTV using VGA Connector
When you connect the vizio try changing the resolution settings on your laptop to see if that makes a difference. Could be that your video card output is not really compatible with the higher requirements of the Vizio.
Open Questions:
Televison & Video Logo
Top Vizio Televison & Video Experts
Ekse
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
