Question about Whirlpool Home
I have a whirlpool tub and need to find some caps to cover the jets. Not sure what brand tub is, sides are all covered. Can you help?
6 jets.
Posted by Nancy on
Bill Boyd
    Top Expert:
  • Whirlpool Master
  • 53,816 Answers
Try a plumbers shop as it is a whirlpool tub
you state that it is a whirlpool tub then you say don't know what brand of tub it is
whirlpool is a brand name
any way the plumbers display of bathroom units and tubs will help you as the jets used are generic and not specific for the tub
Posted on Nov 16, 2015
Aker swrilbath tub want change jet colors
Jet Trim in your jetted bath tub have to be matched up by sight.
Click on the link below to find the brand name of your bathtub, then click on the name.
http://uspartscenter.com/bath-search.aspx
Match up each item in your tub to what is shown online.
If you are unable to match the pieces up to what is shown online to what you have in your tub you may email us photos and we will match them up for you.
send photos to: [email protected]
Rod Kidman
US Parts Center
We locate the "seemingly" impossible...
Ph: 888-521-6183
Fax: 801-417-8027
Apr 06, 2013 | Whirlpool Royal A101A-R Bath Tub
Discolored jet covers
Mar 22, 2013 | Whirlpool Royal A101A-R Bath Tub
I want to replace the 5 jet covers and suction cover for my Spurlin whirlpool tub. Where can I get replacement parts?
Mar 09, 2013 | Home
I have a 1980 kohler jacauzzi tub with 6 jets. Looking through the access cover, at the end of the tub, I can see water dripping from some of the jets. Can I fix this without tearing out the walls around...
no not really the only way to fix it right is to open up the walls. this is a common problem with these units, the best thing you can do is contact the manufacture who made it and ask them what to do.
May 18, 2010 | Kohler 1221-H-0 Seadream 6' Whirlpool Bath...
Jets don't work in the jetted tub.
First the obvious, most are electrically connected to a ground fault device, ether an outlet or a breaker. BEFORE ADDING WATER, check these out to make sure they are not tripped. Most all tubs have a minimum water level which must be reached before the jets will operate. This is usually a piece of trim located above the depth of the jets. Make sure the tub is filled to cover this part. If you cant identify the water level device fill the tub so that all the jets are covered by an inch or 2. Some tubs have push button switches or touch pads to control the motor, some have touch sensitive trim. There may be some sort of medallion from the maker on the tub, simply touching it will start the tub. Once you get it going most tubs have a built in timer that turns off the pump in 15 - 20 minutes. For more tub time just hit the switch again but keep in mind that extended exposure in a hot tub can mess with your blood pressure and cause you to loose balance or pass out, hence the 20 minute timer.
Mar 22, 2010 | Whirlpool Safety Bath Walk In Bathtub -...
How to get jet covers on my lasco tub white they turned yellow
lasco jets usually unthread counter clockwise out of the wall fittings
Oct 16, 2009 | Whirlpool Lasco Builders Choice Ariel III...
Can you cap off the jets of a whirlpool tub if you no longer use the jets?
you can but it's not worth the trouble of doing it! lots of fiberglass and you need to have access to the whole tub on the sides
Jul 18, 2009 | Jacuzzi - Bathtub - Alcove - Navona -...
How do I install a whirlpool bathtub?
here is a link to the some installation and operating instructions.
basically you need to put a 2" x 2" runner under the lip of the tub along the three sides of the tub that touch the walls to support the lip of the tub. that pretty much covers it.
Feb 22, 2009 | Whirlpool 5"x36" White Bathroom Drop-in ...
Whripool covers
The likely hood of finding jet trim for a tub made that long ago is very remote. If you can email us pictures of what you have perhaps we can match them up for you. send photos to: [email protected]
US Parts Center
Jan 13, 2009 | Home
TOP LOAD WHIRLPOOL WASHER BRAND NEW CRACK IN OUTER PLASTIC TUB.
loosen the screw bolt located at the back cover,it has also a plastic lock in the side to side of the plastic cover,find it by sliding a small flat srew.
Feb 21, 2008 | Whirlpool LSQ9610L Top Load Washer
Home Logo
500 people viewed this question
Top Whirlpool Home Experts
john h
Mike
Andrew Taylor
Andrew Taylor
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
