Need to add a carriage return after scanning
SOURCE: I have a ls2208 symbol
Your scanner is set up for full Ascii mode.
$B = CTRL B
%I = >
Re-program to enable "Code 39" and disable "Code 39 Full Ascii"
In Code 39:
$B = Control key on
%I = Tab
Hope this helps.
SOURCE: I am having
Download the product reference guide forr this scanner from www.symbol.com
Find the following barcodes, print them annd then scan then in this order:
scan options.
data > suffix
Enter.
This should resolve your problem.
SOURCE: add carraiage return after scanning
The Motorola support site has an FAQ (ADC-01589) that contains the barcodes to get the LS1902 to add a CRLF after the barcode: Scan Options, Data Suffix, Enter. If the article is no longer there just download the LS1902 or LS1900 series Product Reference Guide to print the barcodes from there. They are usually in the Miscellaneous section.
SOURCE: I have a newly aquired P370 Symbol Scanner and I
One of four reasons for this:
1. The scanner firmware does not support it. Firmware less than rev F does not support the enter- I do not think this is your issue though. You check the firmware revision in the main menu option 4 or scan the barcode out of the Product Reference Guide.
2. Custom firmware on the scanner prevents the enter from being sent. Again check the firmware. If it starts with anything other than an N you should consider sending the device in to Motorola to have it upgraded to standard firmware.
3. The cradle firmware is less than G. If the cradle is less than G it will strip the enter off of the data being sent. If the firmware in your scanner is new enough you can check the revision using menu option 4 in the scanner.
4. An MCL application on the scanner. If you see something other than SKU: on the display the scanner has a custom application on it. The application would have to be modified to add the enter or removed from the device.
