Question about Apple iPad 2 Wifi 16GB
Why won't it reset or charge?
Tried holding down buttons.trys to restartbut goes about a quarter of the way and freezes up again.
Posted by Melissa Billings on
Niall Waldron
    New Friend:
  • 21 Answers
Hi Melissa,
I am sorry to hear this. I am thinking there may either be a hardware or software error. In which case, I have provided a link below to an Help page that may help you with the software side. If the link doesn't help you I suggest you take it to your nearest Apple Store for a Genius to take a look at.
Video Converter Mac
I hope all goes well,
Niall
Posted on Nov 29, 2015
Fully charged. Why doesn't it turn on?
Ruby, try pressing and holding on button or you will have to reset.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Reset Kindle Fire When it Won Turn on or Charge
My kindle won turn on
My kindle won turn on Is it the battery Kindle Fire HD
Amazon Kindle Won Charge Quick Fixes
Mar 12, 2016 | Amazon Kindle Fire HD
Kindle will not shut off-goes to shut off or cancel but wont move. doesnt charge well-doesnt always hold charge
Patricia, Using the power switch, you can forcibly reset your Kindle device. This reset will shut down the Kindle without accessing the shutdown command from within the Kindle's operating system, a particularly useful tool when dealing with a frozen Kindle. To initiate a hard shutdown, Kindle disconnect from its charger, slide and hold the power switch for about 20 seconds. This will force the Kindle to shut down, now it can be restarted normally.
Check links below for charging problems.
Troubleshooting Kindle Fire That Won Charge
Kindle Fire not charging
9 common problems with the Kindle Fire HD and how to fix them
Feb 25, 2016 | Amazon Kindle Fire HD
My kindle screen freezes and/or shuts down repeatedly. What is wrong?
Most likely your memory is low or your battery is not fully charged. You can also reset it by holding the off button for 40 seconds, then press it again to reload. Download an app that cleans junk files from your Kindle.
Feb 04, 2016 | Amazon Kindle Fire HDX 8.9
Screen frozen. Push reset screen goes blank and will not turn on. Put in charger and back to the frozen screen.
Try again. Make sure Kindle is charged. Hold down the on button until you see the fire logo. This usually works.
May 31, 2015 | Amazon Kindle Fire HD
I charged my kindle, but can't get it to turn on
According to Love My Kindle Fire, nearly every Kindle owner will, at some point, need to learn how to "reset" their machine.
"When I hear (or read) these words from those who are experiencing a problem with their Kindle Fire it usually ends with something like, "turn on", "charge", or "work".
If suddenly your Kindle Fire won't work, then its most likely locked up. However, sometimes when it locks up, you can't tell because the screen goes dark (either gray or black). It just looks like it's off when in fact it is already one. cause the screen goes dark, either gray or black. It just looks like it's off when in fact your Kindle Fire is on but is stuck. When an electronic device locks up or freezes usually resetting it fixes the problem. Resetting your Kindle Fire is actually really easy, just hold down the power button for at least 20 seconds. .If your Kindle Fire won't turn on it's possible the battery went dead (if it was left "on" too long).
Plug in the power charger and wait about 15 minutes to make sure it gets enough charge, and then try turning it on again.
If it still won't turn on, try to reset the Kindle Fire again to be sure it's powered off.
If it still won't work, try someone else's charger, in case yours died.
Mar 03, 2015 | Amazon Kindle Touch 4gb, Wi-fi, 6in -...
Won t turn on
Have you held the button in for ten seconds? Are you pushing it in correctly? Did you charge it? If the battery goes down it will not come on. Plug in the charger for awhile then try turning it on. If you spilled something on it you might have a problem. So many things we dont know. Try the charger first.
Sep 05, 2014 | Amazon Kindle Fire HD
Kurio 7 freezes up?
teamviewer has it as needing the partner id
Jan 17, 2014 | Techno Source Kurio Kids Tablet With...
Sony tablet
Option 1 (Non-destructive)
  • Press and hold the power until it powers off. This is considered a "hard reset"
  • Power the device back on.
Option 2 (Destructive)
  • Typically involves powering off the tablet. Once off tap the power button then press and hold Power + Vol Down until you get a menu
  • Us the volume buttons to navigate to "factory reset"
  • Use the power button to select it.
  • This will wipe out the tablet and reset it back to defaults.
Apr 23, 2013 | Tablets & eReaders
My textbook 7p won't turn on
This tablet does t reset with the power button unlike other Android devices. When you hold down the on/off switch, it only drains the battery. If you see the color indicator still charging, allow a full charge.Then, only stay put and pulse the button for a moment quick and let it rest few seconds to try again and again. Only when u see a light coming out of the screen, and I recommend you do this with the power cord on, you hold the power switch down until the rebooting is iniciated. Let go til it is finish and see where the problem is. More likely, like mine, the Settings stop working and needs tune up for the CPU. Never leave an application running when closing your system. With or without internet connection.
Apr 20, 2013 | Tablets & eReaders
Apple iPad 2 Wifi 16GB Logo
48 people viewed this question
Top Apple Tablets & eReaders Experts
gaucherre
Shaukat Bhutto
Shaukat Bhutto
Nicola Conroy
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
