Question about Sharp Office Equipment & Supplies
Clearing service man on 5320 sharp copier - Sharp Office Equipment & Supplies
Posted by NICOLAS on
Jose Altagracia Paredes
    Habit-Forming:
    New Friend:
  • 15 Answers
Hello, NICOLAS
Let me give you, a url when you can find sharp error codes and fix by youself, if you have any other cuestion, please write a comment, im here for help you.
How to solve the h4 subcode 00 error message on sharp AL-2030 copiers
http://www.en.rellenadodecartuchos.com/2014/05/how-to-solve-h4-subcode-00-error-message-on-sharp-al-2030-copiers.html
thanks for comment if need more help
clearing service man on 5320 sharp copier - clearing-service-man-5320-sharp-copier-me3cdhsxedgbgwufhmxd4s52-1-0.png
Posted on Nov 19, 2015
Mutemwa Kapui
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 113 Answers
Enter simulation 20-1
5 Related Answers
Andy Bebb
  • 62 Answers
SOURCE: error code
Hi, H4 is a heater error. Try resetting it by the following; Enter #, interupt, Clear, interupt, display goes dead, enter 14 then print. That will clear the error code, however if you have a problem with the heater it will return. It is probably the thermal fuse has tripped, which is resetable by removing the fuser unit
Regards
Andy
Posted on Jan 22, 2008
Anonymous
  • 62 Answers
SOURCE: Sharp Copier Service Code
You had 5 jams in the fuser the hotarea on the left side of your machine.
Posted on Mar 23, 2008
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: my Sharp Copier AR-5320 print black and white horizontal parallel lines on the documents.
Check for scratches on the drum surface. If you have ran a lot of copies on there, its a good time to get it serviced. It could be the cleaning blade on the drum as well.
Posted on Jul 20, 2008
Benimur
Louie Role
  • 6966 Answers
SOURCE: Sharp AR-5320 Driver
Appreciate the direct "Ask Me". For Sharp AR5316/AR5320 drivers, pls click here. The drivers are for Windows 95, Windows 98, Windows ME, Windows NT, Windows 2000, Windows XP only.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 17, 2008
Anonymous
SOURCE: sharp ar 5320 error code f2
Dear sir.
I have a sharp copier machine AR-5320 when i switched on it shows U2 .Please help me ;
With beast regards
sayed Masood Osmani
Posted on Mar 10, 2009
Sharp AR 5320. How can l clear this error u2?
The U2-40 error can be cleared rather simply. Press P, , C, to enter the service simulation. Enter 16 using the keypad, then the Copy Start button. Press Execute on the screen. Replace the toner cartridge if the error persists.
Read more : http://www.ehow.com/facts_7830455_error-code-u240-sharp-copier.html
Oct 06, 2014 | Office Equipment & Supplies
I HAVE SHARP COPIER, THE MODEL NO IS AR-5320E. I AM HAVING THE PROBLEM OF H4 ERRO. PLEASE HELP ME
check heater section properly,(thermister,thermostat,heater lamp)go service mode and clear error code also
Sep 20, 2011 | Sharp AR-5320 Black and White Copier
My AR-5320 Sharp Copier is Blinking h-4 please send me the code to repair it.
Push the 'clear' button and then the 'auto' button then the 'clear' button and then the 'auto' button again.This should be done as quickly as you can and the console will go blank.Next,select 14,which is the low temp clearing code, and then push 'start' and then turn the machine off and back on again.
Sep 14, 2011 | Sharp AR-5320 Black and White Copier
HOW TO RESET CAL SERVICE MAN AND TO RESET DEVELOPER
Apr 29, 2010 | Sharp AR-5320 Black and White Copier
My sharp xerox machine ar5516 is bleaking a man
Man mean maintenance signal.
Reset : # - Interrupt - C -interrupt press 14 press start key.
If you are not fix try next way.
# - Interrupt - C -interrupt press 16 press start key.
Jan 27, 2010 | Sharp AR-5320 Black and White Copier
Clear seviceman
The service man light is an indication that preventative maintenance is due to be performed on the machine. This is also most likely the cause for the faint copies.
This is true unless there is a code associated with the service man light...check the display for any alpha numeric codes such as H4 or L2 etc.
Oct 19, 2009 | Sharp AR-5320 Black and White Copier
Sharp ar 5320 foud code F 7
Hello sir;E7 that' means this machine laser unit have problem, remove it send it to shop for repair.
May 14, 2009 | Sharp AR-5320 Black and White Copier
138 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
