Pioneer VSX-517-K Home Theater Receiver power does not turn off and everything freezes,the display lights up but no function,does anyone knows whats the problem is
(1) receiver power on then clicks and freezes. (2) does not power off when i press the stand by button. have disconnect the plug to power off
Re: Pioneer VSX-517-K Home Theater Receiver power does...
Ok you might be in the overload zone disconnect everything but power an try unit an functions no speakers nothing just power!Will keep an eye on this post ok!
You guys mentioned the reset via the front panel, and I tried that with this very same issue on my VSX-822-k and it worked!
thought I would post the instructions for anyone else that lands here:
Reset the main unit if the receiver is generally not operating correctly. Switch the receiver into standby mode. Hold down the "BAND" button while pressing the "STANDYBY/ON" button for about two seconds. When "Reset?" appears in the display window, press the "AUTO SURROUND/ STREAM DIRECT" button. "OK?" appears in the display window. Press "STEREO/A.L.C." to confirm. "OK" appears in the window. The system has been reset.
Try this: 1. Turn off the receiver. 2. Disconnect all the speakers from the back of the receiver. 3. Turn on the receiver. Does it still go into overload? If so, it may need repair. 4. If not, turn the receiver back off and connect one speaker at a time and turn it back on.
Most likely one of your speaker cables is shorted out causing your receiver to get overloaded. Or, one of the speakers is damaged, having the same effect.
The First step in this would be to Check the Ohms Limit in the Manual and Compair to the Ohms on the Speakers that you are running and the Ones that came with it. Usually when you By the "Kit" the Speakers are Factory Matched with the Reciever. Let me Know!
I have the same problem. my sandby light is on but my receiver will not turn on! I checked my power going into the power supply board that was good. But i do not have power going to the transformer or the receptacle. And both of my fuses r good. check ur fuses and go from there . If u know how to get a power supply. please let me know.
