Replaced water core and after reinstalling the dash I have no power to anything. No headlights, hazard...nothing. Have checked the fuse box under the hood and have power to those fuses, the fuse box under the dash has no power to it. Anyone have a clue what I might have done? I have repulled the dash and made sure everything was hooked up correctly but still have no power. Any help or suggestions would be greatly appreciated.
SOURCE: No Dash Lights, Keep blowing #2 fuse
i would check the grounding wires. have you tried going to higher ampage on the fuse? There is definitely a short somewhere
SOURCE: headlights and dash light dont work
You would have to check and see if you are getting any power out of the light switch. There is a seperate wire for the headlights and the dash lights.
SOURCE: power windows won t work
There are broken wires in the wiring harness between the frame and your driver's side door. These wires control all the windows and door locks in a 95 Jeep. Same thing happened to me. You will have to cut the rubber boot to get it off and check which wires are broken and repair them.
SOURCE: i need a diagram of the fuse box under the hood,
You tell us Jeep Cherokee (Laredo), in a Grand Cherokee subforum? I confussed.
If this is a Cherokee, review the Repair Manual XJ Cherokee
If this is Grand Cherokee, review ths Repair Manual ZJ-Secc-8W-Wiring-Diagrams (page 7, 9 and 10 for location, details and description). The diagramas can find it in the next pages.
I hope help yuo with this (remember rated this help). Good luck.
SOURCE: I need the fuse box index in a Jeep Cherokee 2003
go to this site it will have exactly what your looking for. a diagram and a list of what everything is.
http://www.wjjeeps.com/fuses.htm
Testimonial: "thank you very much!! i solve my problem... thank's"
