Canon imageRUNNER 8500 Copier Logo
Posted on Nov 16, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannon copier error
Error is E000
  • 1 more comment
  • ziad15327 Mar 17, 2008
    i have a copier canon gp 405 and it displays E005 , how ican resolve this probleme ?
  • dexin May 29, 2008
    the problem is there appears on the LCD (E010 ______) the blank is the chinese letters which we don't understand. the copier we have now is from, i think, China. How can we fix this?
  • partha1957 Jun 19, 2008
    SYSTEM ERROR E000
Anonymous
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Feb 28, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
10
Questions
0
Helped
17159
Points
21
Press additonel function button and press2&8 at once and press additionel functionel button.select COPIER>FUNCTION>CLEAR>ERROR>OK.
for error E0005 replace the cleaning web and go to copier maode select COPIER>COUNTER>MISC>FIXWEB>press clear button on panel
veranki srimannarayana
Level 2:
Sniper:
  • Expert 54 Answers
  • Posted on Aug 03, 2008
Expert
Level 2:
Sniper:
Answers
54
Questions
Helped
36956
Points
155
E000 is a fuser probleb.check the film/lamp continuty.for E000/1/2/5clear error in service mode as follows
press additonel function button and press2&8 at once and press additionel functionel button.select COPIER>FUNCTION>CLEAR>ERROR>OK.
Anonymous
Level 2:
  • Canon Expert 270 Answers
  • Posted on Nov 16, 2007
Anonymous
Canon Expert
Level 2:
Answers
270
Questions
0
Helped
198461
Points
578
This error identifies a heating problem with the fuser ( fixing ) assy. This normally has an error reset procedure that has to be done after fixing the heating problem. This also includes E-002/3/4/ errors as well E005 ( Cleaning web ).
3 Related Answers
Muggs01
Muggs01
  • 72 Answers
  • Posted on Jan 16, 2009
SOURCE: cannon image class D880 System Error E000
1. Hit Additional Functions Key
2. Hit # key
3. Arrow to number 7, Printer and hit Set
4. Arrow to number 4, Printer Re-Set and hit Set.
5. Yes, re-set printer (hit minus key - back arrow).
6. Unplug the machine and plug it back in.
hamzaskilltd
amir hamza
  • 318 Answers
  • Posted on Jun 01, 2010
SOURCE: cannon ir1600, System Error E000.
heat roller low temperature detection
Nikolay Boychev
  • 525 Answers
  • Posted on Jan 27, 2011
SOURCE: Cannon-3300 Copier Error code E000-0000
E000 0000
The reading of the main thermistor does not reach 30°C 1 sec after the main
power switch is turned on. Or, it does not reach 70°C 2 sec thereafter.
Main cause:
The fixing film unit is faulty. The main thermistor has an open circuit. The
fixing heater has an open circuit. The main power supply PCB is faulty. The
DC controller PCB is faulty.
Caution:
To reset the error, execute the following in service mode:
COPIER>FUNCTION>CLEAR>ERR.
Action:
1. Connector
Is the connector of the fixing assembly connected?
a. main power supply PCB (J8) <-> relay connector <-> heater
b. DC controller PCB (J320) <-> relay connector <-> thermistor
NO: Connect the connector.
2. Fixing film unit (thermistor)
Check the interval between pin 1 and pin 2 and between pin 3 and pin 4 of
the connectosr (4-pin) of the thermistor for electrical continuity. Is it ¥W
(open)?
YES: The heater has an open circuit, or the thermal switch is open. Replace
the fixing film unit.
4. Main power supply PCB, DC controller PCB.
Press the Start key. Is the drive voltage of the heater supplied by the connector
J8 of the main power supply PCB?
Main heater: between J8-1 (FSR1) and J8-5 (FSR COM)
Sub heater: between J8-3 (FSR2) and J8-5 (FSR COM)
YES: The heater drive power supply is faulty. Replace the main power
supply PCB.
NO: The thermistor control mechanism is faulty. Replace the DC controller
PCB.
Cannon IR 2002N Error E000-0000
ir 2020 e0000 means no heat . fuser or fixing assembly.several possibilities thermal switch, lamp, thermistor, lamp connectors. its in the fuser.
CANNON PC 1060 SHOWING SYSTEM ERROR E000 ?
Hi; E000 fixing unit problem Contact heater oxidized or blown
40helpful
3answers
Cannon image runner 2200 error code E000002-0000, how do I fix it?
E002/E000/E003/E261/E733 Error code: Due to AC line noise Error Code
Symptom E002/E000/E003/E261/E733: due to AC line noise. Description E002/E000/E003/E261/E733 occur due to AC line noise.
If the above error codes are frequently recorded in the error log, they might concern AC line noise. Cause When the machine tries to detect a Zero-cross signal of AC line, it will fail if a noise occurred around the zero-cross point. Since the fixing temperature is controlled based on the zero-cross signal, there is a possibility that the fixing temperature could not rise properly if a noise occurs several times. Field Remedy Replace the Switching Regulator PCB ***'y with a new one.
120V: FH3-2613
220V/240V: FH3-2614
The circuit has been modified to resist a noise. REMEDY Caution
 Press (* then 2 and 8 together then *)you are in service mode monitor:
To clear the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
GOOD LUCK MATE ......KINDLY RATE ME !!!! THANKS.
8helpful
System error for cannon 1670f
Press the usermode star-the star just above the lcd display-and then # key,scroll with the arrows until clear is displayed press ok and scroll again untill ERR is displayed press ok,Swotch the machine off and on again.
3helpful
My cannon ir 1600 gives e000 system merror, could u pls help me
E000 indicates a Fuser (Fixing) Unit error.
Some can be reset, others need a part replaced.
1helpful
Printer D880 Cannon System error E000. What will fdix it?
From a fellow FixYa expert, "Press "Additional Functions", press "#", then press the "Right Arrow" button till it says, "Printer", then press "Set" then press the "Right Arrow" button again until it says "Printer Reset" then press "Set" again, the display will ask you "Yes" or "No". Press the "Left" arrow for "Yes", then press "Set". Now, unplug the power cord and wait 5 seconds and plug back in. If this don't work, get a new fuser."
Error message on printer E000
E000 is a fixing unit problem. It could just be needing to be reset or replacement of the fixing unit or if that is not the fix it may coast more then it is worth.
16helpful
4answers
Error code E000 on a canon imageclass D761
in service mode (additional function then pound sign) go to number 7 hit set go to 4 hit set push left arrow for yes set then unplug and replug
2answers
System Error E000
Since there are few techs who can function on telepathy alone, a make and model number is mandatory.
Make; model #; description of problem, and it wouldn't hurt to mention (generally) where you are located.
There isn't a 'generic problem' within even a particular manufacturer's machines; most have varying sets of error codes within series of machines since they may be equipped differently.
old marine
old marine
ZJ Limited
ZJ Limited
