Question about Vizio E500i-B1 50-Inch 1080p Smart LED HDTV
How to get rid of a vertical black bar on my VIZIO E500i-B1? It runs 3 inches wide, from top to bottom of the TV. Power panel was replaced recently.
Posted by Steffen Mi on
Clive Christie
    New Friend:
  • 26 Answers
Bad panel
Posted on Jan 28, 2016
5 Related Answers
Anonymous
SOURCE: brand new Vizio 42 in from Sams has a 5 inch vertical grey stripe from top to bottom-any help removing it?
take it back!
Posted on Jan 22, 2008
DRACO A5OG
Jim Chang
  • 22 Answers
SOURCE: vertical red line on my Vizio plasma
Spent 3 hours removing all what seemed like 100 freaken screws.
Took out the OEM 038A, caution the factory placed some type of heat transfer silicon clear grease on the back of the board so it will feel like it is glued on. Just be very carefull and gentle when prying it apart.
Be warned, you will need a magnifying glas to check those little resistors. They all checked out, no broken solders.
What I did observe is the grease melted down the back of the board and puddled at the bottom of the board and where the resistors sit.
I used rubbing alcohol to clean it all up but left the reside on the square pads. Cleaned the resistors and used a dry paint brush to dust of any lint.
Placed the component back and after 10 minutes the Vertical Red Line Disappeared.
Turned on the set next morning it was still gone. 10 minutes later it re-appeared for a couple of minutes then went away.
I spoke to a kind gentlemen at Electronica-USA.com, he stated that the 060Q is an upgrade to the defective proned 038A ( 038C is also an upgrade ). A tech in Cali stated the 060Q worked perfectly. He has had zero complaints about the 060Q in the Vizio plus he offers a 90 day return policy. Funny thing is the 060Q was designed for LG and Goldstar Plasmas but for some reason they do not work for them but do work for Vizio's. He even states that on his site.
As I type the red line is still gone and stayed off several hours last night.
I think I am going to pull the trigger and replace the 038A to the 060Q and be done with it.
Oh yeah, I asked him if the 060Q needs to be "flashed" with the Vizio program. He never heard of it requiring it.
He has 038C on order they are couple of bucks cheaper. the 060Q is $224 plus S&H.
I found on ebay for $184 free shipping but waiting for the guy to verify no "flash" requirement.
Hope this helps someone.
Merry Christmas and a Happy New Year!
P.S. use a power screwdriver, your wrist will thank you. I put mine on low torque as not to strip the heads.
Posted on Dec 23, 2008
Anonymous
SOURCE: Vertical Red Line
I had a bright red 1" wide vertical line on the right side of my Vizio P42HDE as well as an equivalent Green line on the left. Sometimes a Blue line would appear adjacent to the red line. Had this TV sinc Oct. 2005. Based on internet research, I opted to purchase an LG 6871QCH060Q board (upgrade to the 6871QCH038A and the 6871QCH038C). Picked the board up on Ebay for $100 + $10 shipping from ShopJimmy parts.
From start to finish, this took about 2 hours to repair. Tons of screws to remove. Took me a while to figure out that the video connection unit in the back is completely modular and needs to be removed before attempting to remove the back cover. Once the cover was removed, I was surprised that I could not see where the replacement board was located. Turns out, you have to go one level deeper and remove the audio board and digital board followed by metal bracket/cover. Once removing the metal cover, the bad 6871QCH038A board was visible. A couple of zip ties will need to be cut as well as several cable connections to get to the 6871QCH038A board. Replaced the board with the 6871QCH060Q upgrade. Make sure to keep the sticky foam rubber isolation pieces and adhere them to the new board. It did take some time to figure out how to disconnect and reconnect all the various types of cable connections. Just take your time. The power cable connector for the 6871QCH060Q board is in a different location, thus I had to reroute the cable. Reassembled and only had 2 unused screws left!
TV workd great. Lines are gone. Have a little burn-in going on where the red line appeared, but still better than forking over $800 for a new 42" LCD 1080P TV. Hope to get a couple of more years out of this Vizio.
One line I found has a general example of LG/Vizio repair manual. Not exact, but close enough...http://www.scribd.com/doc/7580885/LG-TV-Plasma-Training-Manual
Posted on Feb 18, 2009
Jim Krause
  • 1779 Answers
If the line is horizontal then it could be a y-drive panel ( depending on from ctr where it is ) whether it is the upper or lower board. Time to let a service company look at it, don't wait, more damage is possible the longer you play it.If it goes vertical ( up & down ) then it could be one of two buffer boards.
Anonymous
  • 10 Answers
SOURCE: I have a vertical black line on the middle of the
You have A buffer board out if the line goes up and down then its the long board going left from right look were the line is and see what board the line lines up on the screen and replace that one
these boards are the closet to the edge of the tv
same process if the line goes across the screen
look for the part number on the board and search with google or go to shopjimmys.com and seach there or call them
Posted on Oct 19, 2009
VIZIO E500i-B1 broke again a month after replacing the power board. Having similar issue
You might want to check the VIZIO website for help. Given how cheap even 4K UHD TV's are today, probably not worth fixing again. Unless under warranty, of course.
Vizio 60" smart tv screen bottom section of the screen is lighter than the top
Sounds like you have some bad lamps in the panel that need changing, in time the backlights will totally go out and the set will have a black screen
Replace wifi module on Vizio E500i-B1
If you wish to get some details; check the site linked here. Pull up older posts.
Vizio e500i b1 black screen, no image
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
My vizio will not turn on. The light on the bottom flashes on and off, but nothing on the screen. I replaced the main board. It worked for several days then went right back this issue.
Have just looked on you tube , I typed in fix for VIZIO E500i -B1 power off and a 2.24 minute video appeared . if that does not solve your problem type the product info and fault again and check the videos that pop up . hope this info is of use to you....
My Vizio e500i-b1 LEDtv went out last night. How can i tell if it's the main board or the tcon board that isn't functioning?
I would verify the voltages on the power supply board first because an improper voltage to a circuit board may make that board look bad.
Open Questions:
See all Vizio E500i-B1 50-Inch 1080p Smart LED HDTV Questions
Vizio E500i-B1 50-Inch 1080p Smart LED HDTV Logo
Top Vizio Televison & Video Experts
Ekse
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
