SOURCE: Sony VPL-CX61 lamp/cover blink. Power on, it
hi,
your projectors lamp cover may be open. or there is some thing happened (may be contact problem) with the lamp cover open sensing switch. just open the door and close it. and then try again.
ok
Testimonial: "Thanks! And please tell me where is the lamp cover located."
SOURCE: Reset Timer Lamp Sony VPL-HS60 projector
To reset the lamp timer:
1) With the projector plugged in and turned off, press the 'ON/STANDBY' button to put the projector in 'STANDBY' mode. NOTE: You have to press the button on the projector itself, you cannot use the remote for this step (this is not clear in manual).
2) Now, using the remote, press the following keys in order: RESET, <--, -->, ENTER.
3) Timer should now read '0'.
According to the manual, you need access to the RESET button, the left and right arrows and the ENTER button to clear the counter. Press the following in order for less than 5 seconds each:
RESET
Left Arror
Right Arrow
ENTER
The above sequence should clear the counter.
Dan
SOURCE: how to reset lamp on sony lcd projector xga vpl-px20
After replacing lamp, connect projector AC power cord and turn the projector in standby mode.
Press following keys on control panel for less then 5 seconds each..
RESET, <==, ==>, ENTER.
That will reset lamp timer in projector.
Thanks.
SOURCE: my Sony VPL-ES3 lamp/cover is blinking. Please
Bulb has gone. And wil cost about £200 to replace, could be time for a new projector
