Machine started grinding for too long, coffee grinds left inside machine, etc. Followed instructions to completely clean machine, and removed and tested the microswitch that measures the dosage. It is normally open and when the button is pressed, it closes. All the plastic mechanical parts for the dosage are clean and seem to move properly. Any ideas? Should I replace the switch anyway? Could it be something in the circuit board? Further troubleshooting steps would be great! Thanks.
SOURCE: Won't power up, after cleaning????
There is a switch that shuts the machine off when the door is open, Be sure machine is on and all components in and press the switch manually and see if it comes on. Some times the switch gets cocked to one side and the activator on the door misses it. Let me know
SOURCE: Saeco De Luxe Coarse Grind
You could have knocked it out of its shaft or worse, Cracked the shaft itself.
Settings could be off too, It fairly common. Recheck the chamber, and make sure the plastic casing isn't cracked and the grinder doesn't wabble at all. It should be fairly firm.
If it isn't firm, bad news, cracked shaft.
SOURCE: Saeco Vienna grinding issue
I think so, most problem with that the grinder grind to the lamp light up is damp in the grinder or oily beans.
if you have two adjustment knob in the bean hopper then the second problems can be the micro switch in the machine that have to be replaced.
Best regards
/Mirran
SOURCE: Hello. I have a saeco vienna superautomatic
This happens due to condensation caused by steam developed at the end
of the grinding cycle. Make sure that the grinding chamber is
completely cleaned and dried before using the grinder.
