Question about HP Photosmart C6180 All-In-One InkJet Printer
C6180 false paper jam
Says paper jam, but there is no jam. have cleaned rollers, removed paper stock, checked carriage. tried hard reset. reset my computer. pulled print cartridges. (once I reinstalled them, got the jam message again.
Posted by Oscar77 on
5 Related Answers
Anonymous
  • 111 Answers
SOURCE: printing crooked, blurred, bad roller?
Sounds like when you pulled out the paper jam, you misaligned the print carriage. That would produce both the noises you hear and the print quality issues. HP.com has a few web pages on their site that might help. The first one deals with noisy print carriages. Unfortunately, it's not dedicated to just your product, but the steps should generally apply:
Resolving Noisy Print Carriage Issues
There's a separate web page available for troubleshooting crooked or skewed printouts:
Printed Text or images are Crooked or Skewed
If all else fails, unplug the power cord from the printer, wait 20 seconds or so, then plug it back in. That should restart the printer and make it go into a self test which may include a realignment procedure. Watch for any error messages on the display on the printer's control panel. Sometimes to realign, it prints out two test pages and instructs you to place the first printout on the scanner bed and then press Enter.
Go to the following web page and when it opens, scroll down to the section "Replacing the print cartridges", and find step 9 in that section for alignment instructions.
Replacing Print Cartridges
Good luck.
Posted on Oct 14, 2008
altaf702
altaf702
  • 28 Answers
SOURCE: HP OfficeJet 6110 All-In-One
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
812
Posted on Feb 28, 2009
Anonymous
SOURCE: Carriage Paper Jam in Photosmart hp c6180 all-in-one-printer
Here's what you do. Take a look at the photo below.
Open the cover of the printer, where the ink cartridges are located. Behind the ink cartridges is the carriage, which is a box that moves side-to-side on a pair of rails. It's the thing that sprays the ink onto the paper.
You have to reach in with your hand and slide this thing to the center. Then, look to the very sides, left and right, for any bits of paper. If you look at the second picture, you can see my finger pointing to a small bit of paper that tore of and got jammed into the side. See the little crumpled bit of paper? It's preventing the carriage from sliding all the way to the right. You could have little bits on the right or left side. I had to reach in with needle-nose pliers to grab the paper bits out, but maybe your fingers are small enough.
Once the little bits of paper were out, I was back in business. Good luck!
Posted on Apr 20, 2009
Anonymous
  • 26 Answers
SOURCE: HP Officejet Pro L7780 constantly gives false"paper jam" error
Step 1:
The rollers should be cleaned if the paper fails to feed smoothly into the unit. All document and media rollers should be cleaned using a lint-free cloth lightly moistened with water.
1. The unit must be powered down and the power cord unplugged before cleaning the rollers. This will allow the rollers to be turned by hand in most cases. The paper should also be removed before cleaning the rollers.
2. Remove the rear access door to access the rollers. Clean any dust and debris from the rollers.
3. Open the unit and check the four small metal paper rollers (not the rubber rollers) in the interior of the unit. They should be clean and move freely. If these are not bright and shinny or have buildup on them, they should be cleaned. Also clean any dust and debris off of the rubber rollers.
4. Close the unit and reattach the rear access door.
5. Plug the power cord back in and power the unit up. It should reinitialize for about 20 seconds.
6. Print another extended self-test page.
Step 2:
==== Partial Reset ====
Press and hold # and 3 button on the unit while plugging in the power cord.
Note: For models that are not fax capable, press Plus (+) instead of #.
==== Semi Full Reset ====
Press and hold # and 6 button on the unit while plugging in the power cord.
NOTE: For models that are not fax capable, press plus (+) instead of #.
==== NVM RAM Reset ====
Press and hold OK and Cancel button while plugging in the power cord
Posted on May 19, 2009
Anonymous
  • 180 Answers
SOURCE: HP psc 1310 - gave paper jam and print cartridge
clean the rubber rollers of the printer and try to print. if it is still having the same problem. reset the printer by unplugging the power cord of the printer while its turn on. then plug the power cord back in. once the printer is on press and hold the power/on button and the size button. when the on button is flashing then release the buttons and try to print again
Posted on Oct 28, 2009
Why do i have a false jam reading?
I understand that you're receiving what you believe to be a 'false' paper jam on your HP Photosmart C6280 All-in-One Printer. I would like to work with you today with resolving this issue. Paper jams can be real or false. The product might report a paper jam even when there is no jammed paper. A false paper jam may also be the result of having a bad paper jam at a point in time and that bad jam causing a hardware issue to the paper sensor or rollers. I am going to provide you with some additional troubleshooting steps that apply to both real and false paper jams. You did state that you already checked the paper pathway inside the printer and failed to find any evidence of paper being stuck, but please run the step-by-step troubleshooting below, even if you have already run some of the steps.
Here are the steps for clearing the path:
Photosmart c6280 False Paper Jam Messages
Try this blog for alternate clearing ideas for this printer. HP Photosmart C6280 error message Carriage Jam
Jul 02, 2014 | HP Photosmart C6280 Printer
I have a HP LaserJet 1312nfi that is giving me a FALSE paper jam message. I repeat - FALSE PAPER JAM IN BACK DOOR. False false false. I have uninstalled it on my computer and nothing. I have opened it...
Hello Chris! Welcome to FixYa!
If you are facing False Paper Jam error in your HP Laser Jet 1312nfi but If you cant see any obvious paper jams, try to look closely into the rollers or the inside. There could be some tiny paper shreds stuck within those rollers. Or there could be a tiny piece of paper blocking the printer's sensor and thus giving you a false paper jam error.
1. Turn Off the printer and unplugged power before cleaning the rollers. This will allow the rollers to be turned by hand in most cases.
3. Open the back of the printer and check metal paper rollers (not the rubber rollers) in the interior of the printer. They should be clean and move freely. If these are not bright and shinny or have buildup on them, they should be cleaned. Also clean any dust and debris off of the rubber rollers.
4. Close the back cover and reattach the rear access door.
After following these steps carefully, False Error message will be disappeared.
I hope this solution helps you
Let me know if you have any confusion in your mind.
Sir, Your Rating as FIVE Stars for this solution and words of appreciation will be esteemed
Thank You for taking my service
Concerned: Muhammad Uzair
Jan 10, 2012 | HP Officejet Pro L7680 All-In-One Printer
Message appears "Paper jam".
Paper jams can be true or false. A false paper jam occurs when the error message displays, but no jammed paper is in the product. The following solutions apply to both true and false paper jam errors.
Print a self-test report Use the following steps to print a self-test report.
  1. Load plain white paper in the input tray.
  2. Press Setup , and then press 2 . The Print Report menu displays.
  3. Press 1 to select and print a Self-Test Report
Solution one: Clear the paper jam Step one: Remove loose paper from the tray Remove any loose sheets of paper from the input tray and the output tray.
Step two: Clear the jam from the back of the All-in-One
  1. Figure 2: Remove the rear access doorc01562020.gif
  2. Gently pull any jammed paper out of the rollers inside the product.
  3. Carefully remove any scraps of paper that are still stuck in the product.
  4. Reattach the rear access door. Insert the two posts on the right side of the door into the holes on the product, and then push the door in until it snaps into place.
  5. Reconnect the power cord to the back of the product, and then press the Power button (c01602202.gif ) to turn on the product.
Step three: Clear the jam from the front of the All-in-One Follow these steps to remove the paper jam from the front of the product.
  1. Without opening the cartridge access door, check the tray for jammed paper that you cannot remove from the back.
  2. If you see jammed paper, gently pull it out.
Step four: Print a self-test report
  • If the issue persists , continue with the next solution.
Solution two: Make sure that the carriage can move freely Follow these steps to make sure that the carriage can move freely. Step one: Check the paper path
  1. Check for any paper or object that might be stopping the carriage. Figure 4: Example of paper stuck in cartridge access areac01950807.gif
  2. Remove any paper or objects you find.
  3. Reach inside the product, and then manually move the carriage.
    • If the carriage is stuck on the right side , move the carriage to the left side of the product.
    • If the carriage is stuck on the left side , move the carriage to the right side of the product.
    • If the carriage is stuck in the middle , move the carriage to the right.
  4. Remove any paper or obstructions found.
  5. Make sure that the carriage can move freely across the width of the product by gently pushing the carriage to the left, and then to the righ
Step two: Print a self-test report
  • If the self-test report does not print , continue with the next solution.
Solution three: Clean the rollers and the rear access door Dust, paper fiber, and other debris might accumulate on the paper feed rollers and cause paper jams and paper feed issues. Follow these steps to clean the paper feed rollers inside the product. Step one: Clean the rollers
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Disconnect the power cord from the back of the product.
  3. Press in the tab on the left side of the rear access door, and then pull the door away from the product to remove it. Figure 6: Remove the rear access doorc01562020.gif
  4. Lightly dampen a clean, lint-free cloth with bottled or distilled water, and then squeeze any excess liquid from the cloth.
  5. Press the cloth against the rollers and rotate them upwards with your fingers. Apply a moderate amount of pressure to remove any dust or dirt buildup. Figure 7: Rotate the paper feed rollersc00212278.jpg
  6. Make sure that the paper feed rollers on the rear access door are clean, free of paper bits, and rotate freely.
  7. Clean the surface and the rollers of the rear access door the same way you cleaned the large rollers inside the product.
  8. Replace the rear access door. Insert the two posts on the right of the door into the holes on the product, and then push the door in until it snaps into place.
Solution four: Service the product
Aug 08, 2011 | HP PSC 1610 All-In-One InkJet Printer
While printing 2 or 3 lines it shows paper jam message. Can't print even a page!!!
make sure you don't have any small pieces of paper stuck in the printer s.gif s.gif s.gif
Paper jams can be real or false. The unit may report a paper jam when there is not any jammed paper, however, the solution to a real paper jam or a false paper jam is the same. WARNING: Jammed paper must be removed using the rear access door and the power cord must be disconnected or a carriage jam or mechanical damage may occur. Do not remove jammed paper from the front of the unit.
  1. Turn off the HP product and turn it so the back of the unit faces you.
  2. Disconnect the power cord from the back of the all-in-one. The power cord must be disconnected to allow the paper feed rollers to turn freely.
  3. Locate and open the rear access door by pressing in on the left side tab and then pulling the door toward you. Figure 1: Removing the rear access door c00108288.jpg Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door.
  4. Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door. Click How to buy on this page to order replacement parts.
  5. From the rear access door opening, remove the jammed paper.
  6. Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray.
  7. Reinstall the rear access door.
  8. Reconnect the power cord to the unit and turn the unit on. If a carriage stall occurs after clearing the paper jam, resolve the carriage stall.
Jan 10, 2011 | HP Deskjet F4100 All-In-One InkJet Printer
Step 1:
Step 2:
May 19, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Says Paper Jam But No Paper In It
Hi
  3. Locate and open the rear access door by pressing in on the left side tab and then pulling the door toward you. Figure 1: Removing the rear access door bd842f6.jpg
  5. Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door. Click How to buy on this page to order replacement parts.
  6. From the rear access door opening, remove the jammed paper.
  7. Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray.
  8. Reinstall the rear access door.
  9. Reconnect the power cord to the unit and turn the unit on. If a carriage stall occurs after clearing the paper jam, resolve the carriage stall.
Preventing paper jams The following information will help prevent paper jams from occurring:
  • When loading paper in to the paper tray, push it in until it meets first resistance. Do not continue pushing the paper in. If the paper is pushed too far in, more than one page is picked and paper jams result. This is the most common cause of paper jams with the HP Officejet 410 series.
  • Never use paper that is wrinkled or damaged in any way.
  • If you are having problems using paper that has already been printed on once, replace it with fresh paper.
  • Remove and then reinstall the rear access door. Verify that the access door is fully locked in place. The paper can skew if the rear access door isn't locked.
  • Every six months - one year, clean the paper feed rollers with a rag slightly dampened with clean water. Over time the paper feed rollers accumulate dust and do not function as well as they once did.
  • When printing envelopes, tuck the flap into the envelope and crease the folds before printing.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 04, 2009 | HP Officejet 4110 All-In-One InkJet...
Printer 948 false paper jam
Tonight, I fixed my neighbor's Dell 948 printer with false paper jam.
After you lift open the top, look below the shiny bar that the Print Head slides left/right on. You'll see a row of 8 tiny rollers. In between the middle two rollers (rollers #4 and #5 from the left), look for a small plastic tab sticking up between them. Touch this tab with the tip of a ball-point pen to see if it pushes down. If it does, then push the "checkmark" button on the control panel.
That's what I did to fix my neighbor's printer.
Sincerely,
John
Jan 05, 2009 | Dell 948 All-In-One InkJet Printer
Jamming paper
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Dec 30, 2008 | HP Photosmart C6180 All-In-One InkJet...
Paper jam, so small, can't even see paper
first off, unless you know that the paper is there, it's a possibility your machine is just saying or acting as if there is a jam when actually there is something giving a false reading or a failed part rendering it unable to print. Otherwise, if you happen to know where there paper is jammed at, attempt forcing a heavier stock paper through. say the jam is between two rollers attempt pushing a cardstock or index card thickness of stock through the rollers to attempt pushing the paper backward which might either remove the jam and make it removeable elsewhere, or make it so the machine can try to feed the paper through again this time allowing you to reach it.
Oct 28, 2008 | HP Computers & Internet
PAPER JAM
SUGGESTION #1 The print carriage might be jammed. Follow these steps to correct the problem:
  1. With the power on, lift the print cartridge access door. The print carriage should move to the access area located on the right. If the print carriage stays all the way left, reset the unit by unplugging the then plugging in the power cord. If the carriage still does not move to the right, continue with the steps below.
  2. Disconnect the power cord from the all-in-one.
  3. Remove both print cartridges.
  4. Push the print carriage slightly to the left and then to the right to verify that the print carriage is not jammed. If the print carriage will not move, check for obstructions under and around the carriage.
  5. Close the print cartridge access door.
  6. Plug in the power cord.
  7. When the " Insert Print Cartridges " message displays, open the print cartridge access door and insert the print cartridges. Verify that both cartridges are seated correctly and lock into position.
SEGGUSTION #2 cleaning rollers Over time dust and paper fibers will accumulate on the paper feed rollers. This can cause paper feed problems. Follow the steps below to clean the rollers: Figure 3: Paper feed rollers c00212278.jpg
  1. Turn off the all-in-one and unplug the power cord.
  2. Remove the rear access door (as describe above in this document).
  3. Clean each roller using a clean lint-free cloth lightly moistened with water (distilled water preferred). Rotate the rollers to clean the entire surface.
  4. Verify that the paper feed rollers on the rear access door are clean and rotate easily.
  5. Re-seat the rear access door.
  6. Plug in the power cord and turn on the all-in-one.
If these suggestions don't fix the problem feel free to write back to me. Try to be a little more specific i.e does paper feed properly, error message shows with paper/without paper or both, do any of the lights flash when this happens, have you tried diiferent paper sizes ot types. Have you taken it apart to check for any obstructions?
Jan 06, 2008 | HP PSC 2355 All-In-One InkJet Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
157 people viewed this question
Ekse
efs_perpends
efs_perpends
