Sony PlayStation Portable (PSP) Console Logo
r
ryan james sansom Posted on Nov 14, 2015
Im having trouble trying to charge my psp I don't know what it is and cani charge it using a usb
1helpful
How to charge a psp with usb cable while it's dead
no you should use a computer an dplug it in to it and then an orange light should come on then just leave it there for a few hours untill the light turns green
Im trying to charge my psp to my computer using the usb cord but nothing is happing what could that mean?or am i doing it right?
the usb for the psp is only for tranfering data not for charging you still have to plug the original power supply charger in when your psp is connected to your pc
3helpful
Well my psp isnt charging using a usb but i dont no what version it is but i do no it didnt work using usb so i hope u can help thx by
As far as i know you can't charge a psp via usb, you need the factory supplied Ac adapter. The usb is only for adding files/games ecy to your psp. It may trickle charge if you are lucky but as far as i know it wont work to charge like an actual adapter would.
1helpful
3answers
I cant charge my psp with usb
go to settings and check that usb charge option is on... and ake sure its in usb mode
2answers
Psp usb charging problem
ok a psp CANNOT in any way shape or form charge by using a usb cord.
so your kidding yourself if you think u got it to charge off of your pc in the first place.
but that is the problem you CANNOT charge your psp via usb
Chargind psp
If it’s the 2000 series (PSP Slim), then yes. Connect your PSP system to an available USB port on your computer. Turn on your PSP, then under “Settings“, select “USB Connection”. Your PSP should connect to your computer and start charging. It may take awhile, but it will charge it all the way. Hold the display button (The button with the rectangular shape at the bottom of your PSP) until the screen goes black. This will speed up the charging process and is a good method of prolonging battery life when listening to music or other things.
If that doesn’t work, try looking for an adapter lying around your house that matches the volt numbers. The PSP takes 5V. Most portable CD players use 5V adapters and are usually the same size as needed for the PSP. I suggest using an adapter that matches the volt number and fits without trouble. If the orange light doesn’t come on or the PSP acts weird after charging, I’d stop using the adapter. Ask me any questions if you have any. ;)
PSP cannot be charge through wall charger
Maybe the powerpoint that you used isn't working!
Try charging on another powerpoint!
If it isn't the chargers' fault, then it must be your battery, or PSP DC IN connector, where you insert the charger into the PSP.
2answers
Downloading music?
im not actullay sure how you download through the psp. but i do know via computer.
download the song you want.
get your usb connection connected to psp.
go on psp and press (x) on usb connection.
then go to my computer.
open the psp memory stick.
put song in MUSIC
3answers
How to charge a psp with the USB
hi there
i actually have a friend who have a psp slim and he has this accesory(not actual accesory) thats like this.
http://crave.cnet.com/8301-1_105-9775502-1.html
if i could remeber when i tried it one time, it just prompts that the psp is charging.
hope this helps.
2answers
PSP sound ouput
I'm pretty sure the USB port is only for transferring media files. I've searched my PSP head to toe and never heard of anything like that. I've found out you can use the USB connector on the white PSP to charge the battery. (I haven't tried that out yet.)
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
