Installed new battery. good ecu modular said need to over ride security system what do think checked fuses
SOURCE: security system/battery
plz check the following and update me
1. Fuel (To be exact proper air/fuel ratio, normally it is about 14/1)
2. Spark (in appropriate moment)
3. Proper timing (the valves should open and close only in appropriate time)
4. Compression in the cylinders (Normal compression is 120 - 170 psi. The engine won't start if the compression is lower than 70 - 80 psi.)
SOURCE: 2000 porsche boxster won't start.
yes removing the battery sets off the security system and locks out the engine from starting, reset it.
SOURCE: won't even "click" nor " crank" when trying to start .
Agree, it sounds like the starter and it happens often on old Camry. When was the last time you had the starter replaced? The cartalk guys once suggested getting a mallet and bang on the starter and it will work. Eventually you will need a replacement. It is way cheaper to go to junkyard and get a used one (ask them to test before buy).
SOURCE: 97 nissan maxima wont start
go to your pass side door and with the battery connected and lock and unlock the car with the key till the alarm turns off from the pass side
SOURCE: I HAVE A 1993 HONDA PRELUDE VTECH. IT WONT START.
Change the coolant sensor
Testimonial: "YOU ARE THE MAN!!!!!!!! THANKYOU!!"
