Electric Stanley Tre500  Staple Gun / Sharpshooter Logo
A
Anonymous Posted on Nov 12, 2015
Need to replace cord, can't get it apart
What kind of screws are these?
create360
Level 1:
Problem Solver:
  • Contributor 18 Answers
  • Posted on Nov 12, 2015
create360
Contributor
Level 1:
Problem Solver:
Answers
18
Questions
0
Helped
6177
Points
54
One of the screws requires a security torx
How to replace power cord on a nv50126 can't seem to get it apart
A lot of times company with use torx screws and they hide them you have to disable the rear housing. Make sure you watch how you take it apart because you will need to do the revised to reassemble it. Also make sure you put a cord whip on the housing were the cord go' s in
Good luck and just take your time
2answers
How do i replace electrical cord on dremel4000
Open the case, locate the two AC wires and detach. Get new cord and replace as per the previous wire attachments.
Euro Prox Model UV209-11 upright vacuum--
prise it apart I'm pretty sure it has clips much like a computer case.
1helpful
I have a GE D52GW12 rear projection tv. It seems to just loose power and turn off at random times. I already tried different outlets to get it working again.I can get it back working if I wiggle the power...
The tv a/c power cord have internal damages short on the head of the a/c plug itself.This work job is pretty simple if u can do a basic soldering jobs and have tools like a soldering iron and a roll of solders.Look around in ur house for a table portable lamp u don't used anymore unsolders and take that portable lamp a/c power cord.It have very simular design and make of a power a/c cord.Take the tv aparts simplely just unsolder the old tv power a/c cord and replace it with a portable table lamp a/c power cord.Those stars srews on the tv are called Allan wrench screws,must a have a set of Allan wrench screws drivers to use take out this screws out of the tv.Some ealier DLP tvs set made by GE are using these Allan wrench screws,tries to make it much more difficult to take the tv aparts as GE they're trying not to allow tvs owner to take the tv aparts.Or have any friend to help u can do it,have a soldering iron,a rolls of solders,have basic soldering skills.A Allen wrench screws drivers set u can buy it anywhere in a hardware store.
3helpful
How to take apart to replace power cord
In order to access the cord on the Miele S183 upright, you'll need to first remove the handle from the vacuum cleaner. There is a large screw that holds the handle in place that is located under neath of the lower cord wrap hook. Simply remove this screw, and slide the off the vacuum by pushing the handle towards the back of the machine.
Once you have the handle removed, now ope the bag door as if you were going to replace the vacuum bag. You'll see two screws directly above where the bag fits inside of the machine. These two screws will open up the switch and cord housing and give you access to the electrical cord.
You'll see that there are two screws that secure the cord as it comes into the vacuum from the back. Remove both of these screws so that the cord is no longer secured. I think the easiest way to replace this cord is to simply cut the cord (MAKE SURE THE VACUUM IS UNPLUGGED) so that there is about 4-5 inches of the cord jacket (rubber coating around the cord) remaining. You may now just pull this cord jacket off of the cord, along with the paper insulation so you have two bare wires of the old cord. Now take your new cord and push it into the back of the vacuum so that it comes through the switch housing. Instead of having to re-secure the cord with the two screws, I've found that if you tie a small knot in the cord, this works just as well at preventing the cord from pulling through the back of the vacuum.
Simply strip the wires that are left from the old cord, and simply wire nut the new cord after tying a knot (or re-securing it with the two screws), and reassemble the vacuum cleaner. Test the vacuum only after putting the switch housing cover back into place.
If you have any questions about how to do this repair, please feel free to use the clarification request form here on the Fixya repair page. If you found this helpful, please be so kind as to rate my repair as helpful by clicking on the 4 thumbs up icons in the top right hand corner of the repair. This is what keep Fixya's repair professionals continue leaving free repair advice on this site.
Here's a link to a blown up parts diagram to help you visualize how the vacuum comes apart.
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/miele-s183-upright-parts-diagram.gif
Feel free to check out our website for any Miele supplies that you need:
Miele Vacuum Bags, Filters & Belts
Thanks again for rating my repair,
Chris J.
GoVacuum
3helpful
Replacing power cord. How does cannister come
I found the hidden screws under the cord rewind and power buttons.
Need to replace cord on hoover u5720
un do all screws on back of vac replace cord screw back together
Shark euro-pro iron cord replacement model 4750
six screws on bottom plate two hidden under rubber feet on bottom under lower screw holes
1helpful
2answers
Replace power cord
I got the Torx security bit at Ace hardware for a couple of bucks
Top Electric Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you an Electric Tool and Hardware - Other Expert? Answer questions, earn points and help others
