Despite good, smooth engine and plenty of power, this car, once in top gear (Drive), will not step down or even kick-down to any passing gear. Yet, it goes like a mad ape 0-60 if the shifter is moved to manual mode in 2 or 3. "Trak Off & Trak Fail" both light and stay on after 12mph, the shifter's a bit loose but working anyway. TPS fault or any other ideas?
I would be looking for a vacuum operated actuator that down shifts when the accelerator is wide open
could be a failing TCM so have the fault codes read first to get an idea of the problem area
Testimonial: "Yes,I think that Bill might be on the right track even though the TCM, a reader, is not any real trans component. I'll have it read and see."
Hello
The
Engine and Automatic Transmission (not applicable to manual
transmissions) in this vehicles drive train are fully
electronically controlled by a computer called the PCM and TCM (Power
Train Control Module, Transmission Control Module). When a problem
like this or other drive-ability related problems occurs the computer
stores a record of the problem (there are of course some exceptions
to this, like the fuel pump, engine coolant temperature sensor and
MAF sensor for instance) in the form of a fault code in its memory,
to read these fault codes you must have the systems memory scanned
with a special tool. Once the fault code(s) are read you then must
perform the appropriate diagnostic testing to find and resolve the
problem(s) DO NOT REPLACE ANY PARTS UNTIL A TRAINED
TECHNICAIN HAS DIAGNOSED THE PROBLEM TO AVOID SPENDING YOUR HARD
EARNED MONEY ON PARTS THAT MAY NOT CORRECT THE PROBLEM. Also always
check fuel pressure for correct spec for your make and engine type.
Hello
The engine
and transmission in this cars drive train are fully
electronically controlled by a computer called the PCM (Power Train
Control Module). Whenever a problem like this occurs the computer
to this, like the fuel pump, engine coolant teperature sensor and MAF
sensor for instance) in the form of a fault code in its memory, to
read these fault codes you must have the systems memory scanned with
a special tool. Once the fault code(s) are read you then must perform
the appropriate diagnostic testing to find and resolve the problem(s)
DO NOT REPLACE ANY PARTS UNTIL THE DIAGNOSIS & TESTING IS
COMPLETED.
