Computers & Internet Logo
b
bruce dow Posted on Nov 12, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What are the specifications?
Rotation speed capacity usb connection etc
CarlosIjalba
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 125 Answers
  • Posted on Nov 21, 2015
CarlosIjalba
Expert
Level 2:
New Friend:
Cheetah:
Answers
125
Questions
0
Helped
77378
Points
225
You would need to say for what disk drive model, type and manufacturer...
Does this have a 3.0 usb port?
Memory Module Specifications Total Memory Size 6GB Memory Type DDR3 Monitor Specifications Display Type Active Matrix TFT Color LCD Screen Size Connection Type HDMI Maximum Resolution Touch Screen No Media Ports LAN Ports 1 - RJ-45 Ethernet Connector USB Ports (Total) 4
USB Ports Powered (Included In Total) 2x USB 2.0, 2x USB 3.0
Audio Out Jacks Processor Specifications Processor Brand AMD Processor Class A6 Processor Number 5200
Processor Speed 2 GHz Hard Disk Drive Specifications Hard Drives Included Capacity Interface ATA Hard Drive Types Hard Disk Drive
HOW TO FIX ERROR 805 006 ON CANON IR 400
Laser scanner motor cooling fan 2 (FM6)
The fan motor does not
rotate at a specific speed 5
sec after it has started to
rotate.
The fan motor rotation
deviates from a specific
value for 5 sec or more
while it is rotating at a
specific speed.
2answers
Epson t60 is good printer ?
Hi global_sreek,
EPSON is Super fast, affordable & powerful for all your professional photo printing needs.
Features
Increase your productivity with super-fast print speed
• Print instantly from your computer screen at a fast print speed of 12 seconds per 4R photo
Maximise savings with Epson INKdividual™ Cartridges
• Maximise savings and minimise wastage by replacing only what you need
• Epson 6 colour photo ink is highly affordable, keeping daily running costs low
Perfect printing onto CDs / DVDs
• Print directly onto the printable surface of your CDs/DVDs
Compact size to fit any space
• The Epson Stylus® Photo T60 is so compact, it takes up little precious studio space,
freeing it for other uses
Photo perfection with Epson Creativity Suite
• A powerful photo editing software that lets you perfect your photo prints with just one
click of a button
SPECIFICATIONS
Print:
Ink System - 6-colour
Ink Type - Photo Dye(??¥?œ¬??ž?®??š??¼??¸????₪œ?´¢ )
Max. Print Resolution - 5760x1440 dpi (with VSDT)
Min. Ink Droplet size - 1.5pl
Print SpeeD - Approx. 37ppm (Black) Approx. 38ppm (Colour)
Connectivity and Compatibility:
PC-less function - No
Index Sheet - No
Connectivity - Card Slot - No
Connectivity - USB Cable - Yes
Connectivity - Wireless - No
Interfaces - USB 2.0 Hi-Speed
OS Support - Windows 2000/XP/XP-x64 Edition/Vista Mac OS 10.3.9 or later with USB
Network - No
Adobe Postscript - No
Memory Card Backup - No
Ink Cartridges:
INKdividual - Yes
Ink Cartridge Model - 85N Ink Series (Standard Capacity)
Media:
Media Model - S041926E1; S041927E1; S041863; S041464E1; S041285; S042070; S041925; S041332; S041786, S041259
Paper Handling:
Max. Paper Size - A4
BorderFree - Yes
Max. Paper Capacity - 120 sheets
Roll Paper - No
Tractor Feed - No
Cartridge Model(s):
85N (Standard Capacity Black Ink) - Approx 540 pages (ISO/IEC 24711 and 24712 Test Suite)
Page Yield (pages):
85N (Standard Capacity Colour Ink)* - Approx 860 pages (ISO/IEC 24711 and 24712 Test Suite)
Hope it helps.
Thank You for using Fixya.
I have a seagate external drive of a capacity of 250GB. the free space available is 177 GB. the hard disk is very slow? please help?
Are you connecting this high-speed ("USB 2.0") device to a low-speed ("USB 1.1") USB-port on your computer? If so, and your computer has a "USB 2.0" port, connect your device to that port.
If not, then purchase an add-in PCI card for your computer, to add "USB 2.0" port(s).
Why western digita my book elite is sooooooooooo slow coping the data
The speed of copying depends on the speed of the USB ports on your computer, which is either the original USB 1.1 specifications, or the newer USB 2.0 specifications, which is at least FIVE times faster.
So, if your (older) computer has a USB 2.0 interface, connect the W.D. to it, rather than to a USB 1.1 interface.
2helpful
I got canon ir1600 i am receiving an error msg as error 100
as sm -
E100
When the scanner motor is started up, the BD input signal does not arrive
within a specific period of time.
When the scanner motor is started up, the motor rotation is too fast, and
fails to reach a specific revolution within 20 sec at time of deceleration.
While the scanner motor is rotating at a specific speed, the BD input signal
cycle is not within a specific range (±2%) for an equivalent of 10 mm (print
distance).
cycle is not as indicated (±2%).
During the WMUPR period after the power switch has been turned on or
the front cover/left cover has been opened/closed, the drum unit is absent.
Possible cause
The wiring is faulty (short circuit, open circuit). The laser scanner unit is
faulty. The DC controller PCB is faulty. The drum unit is not installed.
Remedy
1) Drum unit
Is the drum unit installed in host machine?
NO : Install the drum unit.
2) Connection
Is the connection of the connector (J908) on the BD detection
PCB, connector (J907) of the laser unit, and connector (J102) on
the DC controller PCB normal?
NO : Correct the connection.
3) Laser/scanner unit, DC controller PCB
Try replacing the laser/scanner unit. Is the fault corrected?
YES : End.
NO : Replace the DC controller PCB.
Borderless printing brother HL- 4040cn
This model can't suppor boderless printing. check this for details.
Basic Specifications Printer Type Laser/LED - Color Form Factor Desktop Color Yes Print Technology Single-pass electrophotographic laser Resolution Black Maximum Resolution, Plain 2400 x 600 dpi Speed First Page Out, seconds 16 Black Print Speed (Draft) 21 ppm Controller Specifications Processor Speed 300MHz Memory, standard 64MB Memory, maximum 576MB Languages PCL6, BR-Script3 Fonts Supported PCL: 66 scalable fonts, 12 bitmap, 13 bar codes
BR-Script3: 66 scalable fonts Special Features Borderless Printing No Automatic two-sided Printing Yes Direct CD / DVD Printing Support No Paper & Media Handling Paper trays, std. 2 Paper Input Tray1 Capacity, sheets 50 Paper Input Tray2 Capacity, sheets 250 Paper Output Bin Capacity, sheets 150 Recommended monthly volume, pages 35000 Paper Types Plain paper, bond, envelopes, labels Supported Paper Sizes Letter, Legal, Exec, A4, A5, A6, B5, B6; Envelopes: Com 10, DL Connectivity Interface(s) 10/100 Base-TX Ethernet, Hi-Speed USB 2.0, USB Direct Interface, 802.11b/g Wireless, IEEE1284 Parallel Network Ready Yes Security Features Wireless Network Security: WEP, WPA/WPA2-PSK (TKIP/AES), LEAP (CKIP), SecureEasySetup Software Details Utilities Interactive Help, Driver Deployment Wizard Windows OS Compatibility List Windows Vista/XP/XP Professional x64/2000, Windows Server 2003/2003 x64 Mac OS Compatibility List Mac OS X 10.2.4 or greater Front Panel Display Yes Physical Details Width, inches 16.5 Height, inches 12.5 Depth, inches 18.7 Weight, lbs 64.2 Additional Details Additional Details - Time to First Page: Less than 16 sec (black)/17 sec. (color)
- Optional Paper Input: Up to 800-sheet total capacity via 500-sheet paper tray
- Multi-Protocol Support: TCP/IP (ARP, RARP, BOOTP, DHCP, APIPA (Auto IP), WINS, NetBIOS name resolution, DNS Resolver, mDNS, LPR/LPD, Custom Raw Port/Port 9100, SMB Print, IPP, IPPS, FTP Server, SSL/TLS, POP before SMTP, SMTP-AUTH, TELNET, SNMPv1, HTTP/HTTPS server, TFTP client and server, SMTP Client, APOP, LLTD responder), Apple’s Simple Network Configuration for OS X 10.2.4 or greater, TCP/IP: IPv6
- Network Management Tools: BRAdmin Light, Web-based Management, BRAdmin Professional, Web-BRAdmin
- Linux OS Support: Red Hat, Mandrake, SuSE, Debian PostScript3 PPD
- Power Requirements: 120 VAC +/- 10% 50/60 Hz
- Energy Star Compliant: Yes
Grand Canyon Tech
Grand Canyon Tech
