Electrical Supplies Logo
A
Anonymous Posted on Nov 11, 2015
Valve lash setting for cat 3412 inlet & exhaust valves
CAT 3412 engine
3 Related Answers
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Apr 01, 2010
SOURCE: tecumseh hm-100 exhaust valve never completely
Bent valve stem?
thesnooper
  • 342 Answers
  • Posted on Apr 07, 2010
SOURCE: tecumseh hm-100 exhaust valve never completely closes
this is a strange problem, the engine would not have left the factory in this condition. are the cam followers the same size ? have they been mixed up.
some engines have an auto decompression which consists of a spring loaded centrefugal weight on the camshaft gear and in order to close the valve the engine has to reach a certain cranking speed in order to compress
Antonio Arellano
  • 89 Answers
  • Posted on Nov 02, 2017
SOURCE: i need to know how to do valve setting on CAT 3412 engine
Go here. If you can stay on without having to pay a fee. found this helpful answer from technician on JustAnswer com
What is the valve clearance on a 226B cat skiddsteer, CAT C2.2 engine
ask CAT this get the service manual
what if it has HLA, and means there is no clearance
no year told
Im at cat now, reading their manuals for you.
and looking at 2.2 spec, (valves)
as you know there are 3 kinds of lash.
  1. none HLA , maybe.
  2. bucket lifters and shims. soch or dohc, NO
  3. valve stem to cam direct, race engines DOHC. NO
  4. and tappet lifters.+ screw adj, called SOLIDs to mech/
yours is rockers and tappets called out.
roller rockers some. (is this a turbo version)
i think I see rocker adjusters there, CAT manuals not free to find
cant find free manual
c2.2 seen here.
internet rumor says
Valve lash setting
Inlet valve ... 0.2 ± 0.05 mm (0.008 ± 0.0020 inch) Exhaust valve ... 0.2 ± 0.05 mm (0.008 ± 0.0020 inch) link to rumor, I'd buy the real manual sure would
https://avsmanual.com/i.caterpillar/i01650698/
Caterpillar 3412 valve lash adjustment
check with cat dealer service center but to get it running .012" inlet hot and .014" exhaust hot is general engineering specs
I have 99 bmw 323i.i ran it hot and got prob fixed and now the eml and a triangle with circle around it comes on dash and car has no power.feels like it has a rev limiter.wats wrong with my car
have throttle body checked also the MDK throttle motor,
make sure that the dealer has followed service bulletin 12 07 99 for procedure to replace the MDK throttle motor
also have them check for codes,here are some codes,
it could be an expensive job,have them check everything,it is most likely the throttle motor,,throttle body is 600 if they switch it,dont let them do it without checking throttle motor,
codes,
MS41, MS42 and MS43 engine DME bmw codes...
• 1 Ignition coil Cyl 2
• 2 Ignition coil Cyl 4
• 3 Ignition coil Cyl 6
• 5 Fuel injector Cyl 2
• 6 Fuel injector Cyl 1
• 8 Air Flow Meter (HFM)
• 10 Coolant Temperature Sensor
• 11 Tank Pressure Sensor (EVAP System) or Radiator Outlet Temp (MS43)
• 12 TPS or Plausibility - Maximum Coolant Temp (MS43)
• 13 Plausibility- Radiator Outlet Temp
• 14 Intake Air Temperature Sensor
• 15 Plausibility - Cut Out Time
• 16 AirCon Compressor - PWM Signal or Plausibility Intake Air Temp (MS43)
• 17 Plausibility - Engine Coolant Temp
• 18 EWS Signal or Camshaft Sensor (MS43)
• 19 Activation VANOS Inlet Valve or Exhaust Valve (MS43)
• 20 "CHECK ENGINE" Light Failure
• 21 VANOS -Electrical Fault or Activation VANOS Inlet Valve (MS43)
• 22 Fuel Injector Cyl 3
• 23 Fuel Injector Cyl 6
• 24 Fuel Injector Cyl 4
• 25 Lambda Sensor Heater -Bank 1
• 27 Idle Control Valve - Malfunction
• 29 Ignition Coil Cyl 1
• 30 Ignition Coil Cyl 3
• 31 Ignition Coil Cyl 5
• 33 Fuel Injector Cyl 5
• 35 Aux. Air Injection System Relay
• 36 DME Main Relay
• 37 DME Main Relay : Delay
• 38 Clutch Switch -Plausibility
• 39 Brake Light Switch or Brake Light Test Switch
• 40 Brake Light Switch or Pedal Value Signal
• 42 Multi Function Steering Wheel- Plausibility
• 43 Multi Function Steering Wheel: Button
• 45 Multi Function Steering Wheel: Port
• 47 Temp Sensor -Downstream of Pre-Cat or Torque Limitation Level 1 (MS43)
• 48 DME Control Unit -Self Test 1
• 49 DME Control Unit or Torque Monitoring Level 2 (MS43)
• 50 EVAP Control Valve or Response Monitoring Level 2 (MS43)
• 51 Shut-off Valve -Charcoal Filter or Request Control Unit Reset (MS43)
• 52 Solenoid Valve -Exhaust Flap
• 53 Idle Speed Actuator
• 55 Lambda Sensor Heater -Bank 2
• 56 Ignition Current Feedback Resistor - Open Circuit
• 57 Knock sensor -Bank 1
• 58 DME Control Unit -Self Test 2
• 59 Knock Sensor -Bank 2
• 61 Lambda Sensor Heater -Bank 2 Post Cat
• 62 Aux. Air Injection System -Switching Valve
• 63 DME Control Unit or Ambient Temp Signal via CAN (MS43)
• 64 Plausibility - Ambient Temperature
• 65 Camshaft Position Sensor (Inlet MS43)
• 66 DME Control Unit
• 67 DME Control Unit
• 68 Tank Venting Valve
• 69 Fuel Pump Relay
• 70 DME Control Unit
• 71 DME Control Unit
• 72 DME Control Unit
• 74 AirCon Compressor Relay
• 75 Lambda Sensor Voltage -Bank 1
• 76 Lambda Sensor Voltage -Bank 2
• 77 Lambda Sensor Voltage -Bank 1 Post Cat
• 78 Lambda Sensor Voltage -Bank 2 Post Cat
• 79 Lambda Sensor Heater -Bank 1 Post Cat
• 80 ABS/ASC interface
• 81 MSR Signal -Active too Long
• 82 ABS/ASC Interface -Advance Adjustment
• 83 Crankshaft Sensor
• 90 Exhaust Temperature Pre Cat Conv - Bank 1
• 91 Exhaust Temperature Pre Cat Conv - Bank 2
• 92 Exhaust Temperature Post Cat Conv -Bank 1
• 93 Exhaust Temperature Post Cat Conv -Bank 2
• 94 Auxiliary Air -Air Mass Flow Sensor
• 95 Auxiliary Air Valve or Auxiliary Air Hose Blocked
• 96 Auxiliary Air Pump - Function
• 97 Auxiliary Air -Flow Rate too Low
• 98 Auxiliary Air -Flow Rate too High
• 99 Auxiliary Air Valve Jammed Open
• 100 DME Control Unit -Self-Test Failed
• 103 VANOS Error -Inlet Camshaft
• 104 VANOS Error -Exhaust Camshaft
• 105 VANOS Error -Position Inlet Camshaft
• 106 VANOS Error -Position Exhaust Camshaft
• 109 Throttle Valve Plausibility
• 110 Pedal Sensor Value Potentiometer 1
• 111 Pedal Sensor Value Potentiometer 2
• 112 TPS Potentiometer 1
• 113 TPS Potentiometer 2
• 114 Throttle Valve Final Stage
• 115 Reference Voltage -Voltage Regulator 1 or Throttle Pedal Adaptation (MS43)
• 116 Reference Voltage -Voltage Regulator 2
• 117 Plausibility -Pedal Position Sensor 1/2
• 118 Plausibility -TPS 1/2 or TPS1/Airflow Plausibility (MS43)
• 119 Throttle Valve Sensor -Mechanical Error or TPS2/Airflow Plausibility (MS43)
• 120 Plausibility Pedal Sensor or TPS
• 122 Engine Oil Temperature
• 123 Map Cooling Thermostat Control
• 124 Activation DISA Solenoid
• 125 Activation Electric Fan
• 126 Activation Tank Leak Pump Solenoid
• 127 Activation Pump Solenoid
• 128 DME/EWS Communication
• 129 CAN Signal SMG 1
• 130 CAN Signal ASC -Timeout
• 131 CAN Signal Instrument Cluster -Timeout
• 132 CAN Signal Instrument Cluster -Timeout
• 133 CAN Signal ASC -Timeout
• 134 SMG Intervention -Plausibility
• 135 Throttle Valve Re-Adaptation Required
• 136 Throttle Valve -Spring Test and Limp-home Position Failed
• 137 CAN Signal -Steering Angle Sensor
• 139 CAN Signal -Tank Level Sensor
• 140 Tank Leak Pump Solenoid - Reed Switch Open or Output Stage (MS43)
• 141 Tank Leak Pump Solenoid - Reed Switch Stuck Closed or Tank Level Sensor (MS43)
• 142 Tank Leak Pump Solenoid - Reed Switch Stuck Open or DMTL Module (MS43)
• 143 Tank Ventilation or Tank Leakage (MS43)
• 144 Fuel System - Large Leak Recognised
• 145 Fuel System - Small Leak Recognised
• 146 EVAP System Leak Detected (Small Leak) or Pedal Sensor Supply Voltage Pot 1 (MS43)
• 147 Pedal Position Sensor Potentiometer Supply Channel 1 (Pot 2 MS43)
• 149 Air Flow Sensor or Pedal Value Sensor Mismatch
• 150 Lambda Post Cat Bank 1 Max Limit
• 151 Lambda Post Cat Bank 2 Max Limit
• 152 Lambda Post Cat Bank 1 Min Limit
• 153 Lambda Pre Cat Bank 2 Max Limit
• 154 Lambda Pre Cat Bank 2 Min Limit
• 155 Lambda Pre Cat Bank 2 No Signal
• 156 Lambda Pre Cat Bank 1 No Signal
• 157 Lambda Post Cat Bank 1 Min Limit
• 159 Lambda Post Cat Bank 2 Max Limit
• 160 Lambda Post Cat Bank 2 (MS41) or Throttle Valve Stuck
• 161 Throttle Valve - Stuck
• 162 Throttle Valve -Control Deviation
• 168 Pedal Position Sensor Pot Supply 1 or MAP Cooling Thermostat Jammed (MS43)
• 169 Throttle Valve Output Stage Cut off after Fault
• 170 DME Control Unit -Self Test Failed
• 171 Plausibility - Throttle Valve
• 172 Pedal Sensor Potentiometer 1/2 Short Circuit
• 173 TPS Potentiometer 1/2 Short Circuit
• 174 Throttle Valve Potentiometer 1/2 Adaptation
• 175 Pedal Sensor 1 Adaptation
• 176 Pedal Sensor 2 Adaptation
• 186 Voltage Post Cat Bank 1
• 187 Voltage Post Cat Bank 2
• 188 Voltage Pre Cat Bank 1
• 189 Voltage Pre Cat Bank 2
• 190 EVAP -Reed Switch Open or Voltage Post Cat Bank 1 (MS43)
• 191 EVAP -Reed Switch Closed or Voltage Post Cat Bank 2 (MS43)
• 192 EVAP -Reed Switch Open
• 193 EVAP -Check Hoses
• 194 EVAP -Large Leak Detected
• 195 EVAP -Small Leak Detected
• 196 EVAP -Electrical Valve from LDP Pump or Barometric Pressure Sensor (MS43)
• 197 EVAP -Barometric Pressure Sensor
• 198 Cat Efficiency during Start -Bank 1
• 199 Cat Efficiency during Start -Bank 2
• 200 Lambda Regulation Bank 1 Pre Cat
• 201 Lambda Regulation Bank 2 Pre Cat
• 202 Lambda Regulation Bank 1 Post Cat
• 203 Lambda Regulation Bank 2 Post cat
• 204 Idle Control System -Idle speed not plausible
• 208 EWS -RPM Signal Error
• 209 EWS -Message Error
• 210 Ignition Feedback Resistor (ZSR)
• 211 Idle Speed Actuator -Mechanical
• 212 VANOS Bank 1 -Mechanical
• 214 Vehicle Speed Signal (VSS)
• 215 Lambda Sensor Bank 1 or ASC/MSR/EML -Interface not plausible
• 216 Lambda Sensor Bank 2 or EGS Position Signal
• 217 CAN bus error -EGS Signal not present
• 218 CAN module -Warning
• 219 CAN module -CAN Offline
• 220 Lambda Voltage Range Bank 1 Sensor 1
• 221 Lambda Voltage Range Bank 2 Sensor 1
• 222 Low Coolant Temperature or Lambda Sensor Control (MS43)
• 223 Lambda Sensor Switching Bank 1 Sensor 2
• 224 Lambda Sensor Switching Bank 2 Sensor 2
• 225 Cat Efficiency Bank 1
• 226 Cat Efficiency Bank 2
• 227 Mixture Deviation Bank 1
• 228 Mixture Deviation Bank 2
• 229 Lambda Sensor Switching Bank 1
• 230 Lambda Sensor Switching Bank 2
• 231 Lambda Sensor Switching Bank 1 Pre Cat
• 232 Lambda Sensor Switching Bank 2 Pre Cat
• 233 Catalytic Converter Overall Efficiency Bank 1
• 234 Catalytic Converter Overall Efficiency Bank 2
• 235 Lambda Heater Bank 1 Post Cat or Pre Cat Signal (MS43)
• 236 Lambda Heater Bank 2 Post Cat or Pre Cat Signal (MS43)
• 238 Misfire Cyl 1
• 239 Misfire Cyl 2
• 240 Misfire Cyl 3
• 241 Misfire Cyl 4
• 242 Misfire Cyl 5
• 243 Misfire Cyl 6
• 244 Crankshaft Interval Timing
• 245 Aux Air Injection System Bank 1
• 246 Aux Air Injection System Bank 2
• 247 Aux Air Injection System -Incorrect Flow Detected
• 248 Pre Cat Converter Efficiency -Bank 1
• 249 Pre Cat Converter Efficiency -Bank 2
• 250 Tank Venting Valve -Function
• 251 Tank Ventilation Diagnosis Error
• 252 Tank Ventilation System Vacuum
• 253 Activated Charcoal Filter Shut-off Valve Stuck Shut
• 254 Tank Ventilation System -Large Air Leak
• 255 Tank Ventilation System -Valve Stuck Open
Can anyone help? i need torque settings for head gasket and settings for inlet tappets and exusht
Find complete torque specs here:
http://fme-cat.com/LiveDocs/99999.pdf
and don't forget that you MUST buy new head bolts since they are torque to yield and MUST OT be reused!!
I suspect that you at least need to check the valve lash but as long as your head gasket is not dramatically different than original (which it should not be because that would change your compression ratio) you should be close to okay (I would check it). Or if you had any machine work done to the head, in which case you certainly would need to adjust the valve lash.
What is the valve adjustment order when setting valve lash on Isuzu 4jg2 engine
The tappet adjustment is 16thou or .4mm for both inlet and exhaust.
Remove the rocker cover.
Turn the engine over till the timing mark on the pulley lines up on the pin in the cover.
Try to move the rockers on no1...if they are loose and four are tight you are on TDC no1 other wise you are on TDC 4
If on TDC one,
From here you can adjust inlet exhaust on one, inlet two, exhaust three.
Turn the engine 360 degrees one will be tight and 4 will be loose...so now you can adjust both inlet and exhaust on 4, inlet on three and exhaust on two.
HOW TO MAKE VALVE SETTING FOR CAT 3412
i don't have answer to my question how to valve lash the Cat engine
3412 Generating set
How to adjust valve lash on a 1990 Geo Storm
its an Isuzu engine.
there are 3 engines.
4XE1, SOHC 1.6L (base)12valves
4XE1, DOHC , 1.6L same as above but now with 16valves.
4XE1, DOHC, 1.8L bends valves if belt snaps...
note the bad idea of ISUZU calling all 3 engine same name.
a horrid idea.
which one? the second was in USA and Canada only.
the second one was offered as the GSI. is yours that?
so I will attempt to guess for you, its the base engine.
(odds of coin toss)
toss #2, USA, SOHC
guess 3: did a new belt and want to do lash next. Cam belt>
No job stated so i guess 3 times.
Just lash.
SOHC 1.6L only (FSM book quote)
Check the valve lash between the rocker arm and valve stem on both the intake and exhaust valves on the number 1 cylinder, the intake valve(s) on the number 2 cylinder and the exhaust valve on the number 3 cylinder. If the valve lash on the intake valves is not 0.006 in. (0.15mm), adjust the valve lash. If the valve lash on the exhaust valve is not 0.010 in. (0.25mm), adjust the valve lash.
1.6L twin cam has shims.
1.8L has HLA , no lash to set.
HLA= Hydraulic Lash adjusters.
I posted this before, search for it. Im only doing 1 engine.
Arctic cat utv
I would guess intake ans exhaust valve lash issue but would need more info please
2helpful
Engine lost power on a 2004 ford escape and then blew a hole in the egr valve. could this mean a plugged cat converter?
Yes this could be the problem, because you are having backpressure, which is usually the cat, or worst case scenario, you may have a bent or stuck exhaust valve...But what you can do, is disonnect the cat., or the exhaust, and let it run...Now its going to be loud, but if you dont have that back pressure then you know its just the cat., but if you still have it, then you know it maybe a bent or stuck exhaust valve....
Top Caterpillar Electrical Supplies Experts
deton8 von Splosion
CJ Rock
CJ Rock
ADMIN Eric
ADMIN Eric
Are you a Caterpillar Electrical Supply Expert? Answer questions, earn points and help others
