Question about Tatung V23DLWX Television
Is the iLO v23dlwx the same as the Tatung V23dlwx
If it is do you guys know if there is a hardware reset there is emty static like off channel anologe tw sound on all inputs no sound on TV and no picture on TV but the other inputs have picture.
Menu seems to work except the reset on the menu will not change to yes it clicks over and then right back.
Robin Wilson
    New Friend:
  • 25 Answers
Www.polaroidsupport.com/polaroid/docs/FLM-3001ServiceManual.pdf
Posted on Nov 18, 2009
Anonymous
  • 4 Answers
Here is a manual that may help.
http://pettersservice.com/polaroid/docs/FLM-3001ServiceManual.pdf
Posted on Jul 18, 2008
Firstly, CAN??, and then how do I get an NEC NLT-19XT1 television to work with a TEAC High Definition Digital Receiver HDB848 HDMI, please. Anyone know how? Appreciate all the help I can get. Thank
Id the TV Anolog or Digital? If it is analog, then the digital receiver must have RCA outputs to meet the TV's RCA inputs. To make an old analog TV work (meaning getting a picture), you have to check id the receiver has RCA or S-Video outputs. If so, then connect an RCA cable with yellow into yellow, red into red and white into white and then connect the same colors plugs to the yellow, red and white to the RCA inputs of the TV. Or, you can connect a S-Video cable plugs in the output of the receiver and the input of the TV, disconnect the yellow RCA plugs at both the receiver and TV sockets and leave the red and white cable for sound only, as S-Video has an improved video signal, therefore better picture quality. On the TV you have to select an AV input channel, like AV1 or AV2, etc. The same channels that you had used when you were once watching VCR tapes on analog TV. Hope this helps.
Nov 17, 2014 | Televison & Video
Can't get balance, bass and treble to work when connecting Bose Acoustimass 5II to HK AVR 525
On my yamaha 375 receiver if I connect digital or hdmi it disables the balance/bass treble etc but they work with anolog don't know if yours might be the same just abit strang if anolog doing it aswell
Jan 15, 2014 | Harmon Kardon Harman Kardon Avr 525 7.1...
TV displays "no signal" with every input type we try. The only thing that works is the DVD. I even tryed it on a cable cord that was working from another TV
hello are you using a digital antenna, cable or satelite reception? you need to run your "set up" and scan for channels either automatically scan or manual scan, recomend a auto scan for all channels both digital and anolog, these tv will scan and save or store the channels but you need to run a channel scan first,
(even if your using a cable box or sat box)
back when we had the older anolog sets you could just plug it in and watch but with these new digital circuts need to scan and store the channels in before you can watch the broadcasts,, try that let me know what happens. hope this helps
Jun 05, 2010 | Olevia 227-S11 27 in. LCD TV
I just lost all my digital channels. The problem started yesterday and continued today. When I changed to a channel the TV would give off a load crackle sound and the picture and sound would disappear....
this is what i can tell you your tv has 2 boards a main one and a power supply one anything that has to do with your imputs tv, av, hdmi, etc has to do the main that includes the picture going off and sound you can contact the manufacturer and tv technicians, but the only place that its going to be cheap its at www.shopjimmy.com guaranteed
Apr 13, 2010 | Element Electronics FLX-2610 26 in. LCD...
When using cable input video is good but sound has fuzzy static
Your TVs tuner tuned a little off frequency. It could be as simple as having cable box on where you have good picture but fuzzy sound, use the TVs remote to change the channel and then change it back to proper channel. If that doesn't fix you may have wrong tuning type selected in channel set up menu.
Oct 11, 2009 | Toshiba 27A30 27" TV
Watching tv sound goes static
Hi there, this is a tuner issue. it can be repaired or replaced.
Feb 20, 2009 | Philips 47PFL3603D LCD TV
Digital channels
MAYBE CHECH UR DIGITAL RECIEVER CONNECTIONS AND PORTS.THEY ARE NOT YET ATTACHED.SWITCH YOUR INPUT TO THE DIGITAL MODE
Jul 02, 2008 | Sanyo DS31590 31" TV
Connecting new tv to DRA-685
you can use the headphone jack just get an adaptor to change from the headphone type to RCA type. adjust the volume of the tv to 3/4 of the way to give line level to the stereo, use an aux input on the stereo. if you had a suround sound dolby digital / DTS receiver then use the digital coax out to that type of receiver, but since you have an anolog 2 channel receiver you must use the only anolog source (the headphone).
May 21, 2008 | Denon DRA-685 Receiver
Tatung V23DLWX Television Logo
619 people viewed this question
Top Tatung Televison & Video Experts
CoppellTVRepair.com
Muntejaya Ginting
Muntejaya Ginting
Are you a Tatung Televison and Video Expert? Answer questions, earn points and help others
