Question about ESQ Watches
I have a ESQ E5262 stainless steel and the band is a little tight. I am looking for a band link.
Bill Boyd
    Top Expert:
  • ESQ Master
  • 53,813 Answers
Go to a jeweler or watch maker as they often have spare links from bands they adjust in shop when making a sale
take the watch in to match the links
Posted on Nov 11, 2015
5 Related Answers
Pierre Laplante
  • 2042 Answers
SOURCE: Lost screw
go to any jewelery store cheers
Posted on Jan 19, 2008
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: stainless steel band won't snap into my watch
Stainless steel bracelet ends (so called wings) must be curved flush to the watch case.
Another way is to use curved spring lugs (pins).
Posted on Dec 17, 2008
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: stainless steel band adjustment
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Mar 19, 2009
Anonymous
  • 3 Answers
SOURCE: I need extra links for my fossil BQ-8792 watch.
Go the Fossil website - http://www.fossil.com. There is a link at the bottom of the page, Customer Care. Clock on that link. On the left there will be a menu item under Product Info that says "ordering links and bands". There is a paragraph titled "Order Links". There is an 800 number to call and they will send you two links just for shipping or if you need more than 2 links, it's $3 per link.
Posted on May 15, 2010
Anonymous
  • 19 Answers
SOURCE: How do I remove watch band links from m Stainless
I've got a great article that helped me out with this same problem! I thought this article explained things pretty well. http://hubpages.com/hub/How-to-Size-a-Watch
Posted on May 24, 2010
Looking for band for invicta sea spider 1261..i want to replace it with a stainless steel band..
Sea Spider 1261 INVICTA Sea Spider Men 50mm Stainless Steel Gold Black dial 3600K Mechanical watch located attached link offers multiple compatible straps
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jamie_580d75bd3bb6d659
Nov 11, 2017 | Invicta Watches
Esq bracelet watch stainless sku 905-00001 -smashed steel-crystal estimate
Any watch repair shop will fit new crystal and give real time estimate.
May 18, 2011 | ESQ Watches
My band has broken, and I've lost two of the links. Can I get replacement links or a replacement band?
mcdevito75 here, Look for a small watch repair shop in your area for replacement.
Jun 29, 2010 | ESQ 7300698 Watch
I need an extra link and the receiving end clasp for my fossil steel fs 2700 watch. Anyone know where to get?
Go to "fossil.com", go to the bottom of the page and you will see a menu, click on "customer care" and then look under "Product Info" on the left and you will see "0rdering links and bands"
Feb 14, 2010 | Fossil Stainless Steel and Leather...
I just need to remove 2 links and I do not want to damage the band... can you help me? ESQ by Movado
Take this to a jeweler or pound out the pins with a paperclip width rod of steel or pin pusher and a hammer.
Oct 16, 2009 | Lucien Piccard 26024 Wrist Watch
How to open Baume & Mercier Hampton Milleis ladies stainless band
Looking at your watch it looks like the clasp on the SS model is just a double deployant preasure fit. If it is brand new sometimes these style of deployants are vary tight.
It is Stainless Steel it is vary difficult to break it looking at the construction of the bracelet.
Basically you just Pull, there is no button it is just pressure fit.
mike -- consumerwatchguide.com
Jan 01, 2009 | Baume Et Mercier Hampton Milleis MOAO8242...
New band
You can either contact Movado directly (they make the esq watches) or you can ask any REAL jewelry store to contact the company for you and ask about this as long as they carry either Movado or Esq in their store (don't ask the jewelry counter at your local department store).
Dec 30, 2008 | ESQ Swiss Muse 07101116 Watch
Stainless steel band won't snap into my watch
Dec 12, 2008 | Philip Stein Teslar Large Gunmetal Watch
Watches Logo
202 people viewed this question
Top ESQ Watches Experts
Janelle Schoonover
Janelle Schoonover
Bill Boyd
Marvin
Marvin
Are you an ESQ Watch Expert? Answer questions, earn points and help others
