Question about Insignia - Flex 8 inch Tablet with 8GB Memory
How do I uninstall apps? - Insignia - Flex 8 inch Tablet with 8GB Memory
Posted by jose medina on
I have a samsung tablet. I am trying to delete a game and reinstall it so i can start from the start. But it always goes vack to where i was upto.
go to play store go to my apps then go down to the app you want to uninstall press app uninstall it and then when uninstall press install
Feb 28, 2018 | Samsung Tablets & eReaders
How do I delete all my google apps
You can remove apps from your device if you don't want them anymore or you need to clear memory space. If you uninstall an app you paid for, you can reinstall it later without buying it again.
Uninstall or disable apps
  1. Open your device's Settings app .
  2. Tap Apps or Application manager.
  3. Tap the app you want to uninstall. You may need to scroll to find the app.
  4. Tap Uninstall or Disable.
Uninstall vs. disable There are two ways to remove apps depending on whether you downloaded the app or if it came preinstalled on your device:
  1. Uninstall downloaded apps: If you downloaded an app from Google Play, you can completely remove it from your device.
  2. Disable preinstalled apps: Some apps come preinstalled on your device. You can disable these apps, but you can't remove them completely. After an app has been disabled, it will be hidden on your device.
Note: Disabling a system app may cause other apps to misbehave and will delete your associated data for that app.
You can find more information here:
https://support.google.com/googleplay/answer/2521768?hl=en-GB
Dec 05, 2016 | Tablets & eReaders
How can I uninstall,preinstalled apps ?
In Settings > Apps > All you can see a list of all apps that are on your device. You can touch the one(s) you wish to uninstall and more detailed information will appear. There may be a few that have an *uninstall* option. For those that do, simply touch the uninstall button and they will be uninstalled. Those that don't have an uninstall option you are stuck with. The best you might be able to do to reduce the space they take is to disable them if they have that option listed. Also you can clear cache and data on those you don't use or want and that will also clear up some space.
The only other way I know of to get rid of native apps is to *root* the device so you have superuser privileges and then you can delete anything you want to. But, rooting by those who don't know what they're doing can result in *bricking* a device.
Jun 13, 2015 | Double Power Nobis NB09 9" 8 GB Wi-Fi...
Last Gmail I looked at is locked on screen on right side.
Close GMail first by swiping it off the running apps screen.
Uninstall GMail using the *Uninstall* option in:
Settings > Apps > Downloaded > GMail. Touch GMail and you will get another screen with an option to uninstall it. Touch the uninstall button and it will uninstall.
Then go to the Google App Store and download it again. It sounds like the Mail app got corrupted somehow.
May 11, 2015 | Tablets & eReaders
Hasn't saved anything to the memory card because his tablet won't allow him to .. It keeps saying not enough space it's a 8GB memory card
The internal memory cards of some Android devices are partitioned for app storage and installation. Some of them have partitions that are quite small such as one Gigabyte or smaller. The remainder of the storage cannot be used for apps.
If it keeps saying not enough memory space then chances are the app partition is full. The only way to free up some space is to uninstall some apps that are stored there but not being used. You can see which apps can be uninstalled in Settings > Apps and look at them one by one to see if an uninstall option is listed. Simply click *uninstall* to remove them from the app storage partition. This will free up some extra space for some new apps or for updates to older apps you still like and use.
Also some of the apps might show an option to move them to an external SD card (if your device has a slot for one and if an SD card in inserted therein). Do move any and all to the external SD card of you have that option as that will also free up that space from the internal SD card.
Facebook comes up in blank lines
Go to Settings, select facebook, press uninstall or update, which option is available to you.
If uninstall, then the App will be uninstalled, after which you should re-install the app by going to App-Store and locate Facebook App there, to reinstall.
If Update, then you should select this option and lets the App update itself and try it Again. If problem still occurs, then uninstall as described above.
Mar 03, 2015 | Apple iPad 2
How do I remove permanently Big fish casino app from my I pad
Bring up all your Apps icons on Ipad, then touch the Settings symbol and a pop-up box appears. Find the word Uninstall, usually has a rubbish bin icon. Then touch on Uninstall and the screen changes to uninstalling mode. swipe/scroll left or right until the Installed Apps appear. The Installed Apps are usually marked. Find your Big Fish app and touch it. A Delete confirmation message appears. Touch the Ok button to delete it.
Dec 28, 2014 | Tablets & eReaders
How do I remove unwanted apps? I see no uninstall.
From settings go to app manager. Find the app and tap uninstall.
Oct 05, 2014 | Worryfree Gadgets 7inch Zeepad 7.0 Android...
Have ematic 003. When I uninstall any of preloades apps, it shows uninstall and the app no longer appears on the tablet. But the next time I turn on the tablet all the uninstalled apps are back.
It is not possible to uninstall preloaded apps on your tablet unless it is rooted. Then you have to check to make sure that no other services on the tablet depend on that app as it could mess your tablet up
Apr 30, 2014 | Ematic Tablets & eReaders
Insignia - Flex 8 inch Tablet with 8GB Memory Logo
57 people viewed this question
Top Insignia Tablets & eReaders Experts
Harrie
matt
matt
Claudio Roque
Claudio Roque
Level 1 Expert
Are you an Insignia Tablet and eReader Expert? Answer questions, earn points and help others
