If you would please look at the glass and the metal door in which it attaches, I believe you will see there is a black "tar" that holds it in place.
First, disconnect the electric rear window defroster wire, if you have one.
You would, using a very thin steel wire, separate the glass from the "tar".
Then, clean the tar out of the channel, and prepare the rear door for new tar and the new glass.
It sticks on.
SOURCE: factory boston acoustic amplifier location
The factory amp is located under the steering column. Here is a pic. Good luck!
SOURCE: MY SUNROOF IS STUCK OPEN IN MY 05 DODGE MAGNUM
Hello. Begin by checking the fuse that controls the sunroof, just look in your owner manual under fuses and you will find a diagram and location for where to look. If the fuse is bad, replace it with a new one of the exact same amperage. Also, use a can of pressurized air [like a computer duster] and clean the rocker switch that controls your sunroof, try to blow air behind it on both sides. Finally just rock that switch back and forth rapidly several times which may break the motor free so it will work again. Regards, Joe
PS please rate my answer. Thank you.
SOURCE: WHERE IS THE IAT SENSOR LOCATED ON AN 05 DODGE
Welcome to FixYa.com, Thank you, Lee Davidian
SOURCE: Transmission will not shift first
CODE P2767 - TRANSMISSION INPUT SHAFT SPEED SENSOR TURBINE SHAFT SPEED TSS SENSOR B NO SIGNAL.POSSIBLE CAUSE SHORT IN WIRE CONNECTOR OR FAULTY TSS SENSOR OR TURBINE SPEED SHAFT SENSOR.
